The dreaded 30 second blinking oil light at startup - anyone have a fix for this? - Defender Source
Old November 19th, 2004, 05:54 PM
solihul
Rover
Well I just changed my oil and after a few days on startup I get the oil light blinking for about 30 seconds. Is it most likely the sender? I hope as the logic unit is like $400.00.
Suggestions/experiences appreciated.
Old November 19th, 2004, 07:07 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Stfu
what year and type of Land Rover do you have?
Rob
Old November 20th, 2004, 02:43 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Most likely the sender, change tht first because its cheap. If that doesn't work it could be that the pressure relief spring is weak (in the oil pump) or there's some muck stuck in the pressure relief valve holding it open slightly.
Mike Hammond
Old November 20th, 2004, 10:22 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I agree with Mike 100%. Do you have a distributor driven oil pump or cranksaft driven (or was it cam shaft driven--I am having a moment..)
Old November 28th, 2004, 11:29 AM
mikeslandrover
Mike Hammond
The oil pump is driven off of the bottom of the distributor I think
Mike Hammond
Old November 28th, 2004, 01:18 PM
Thats right, on a 94 it is driven off the distributor
Old November 29th, 2004, 03:48 PM
mikeslandrover
Mike Hammond
You can spin the oil pump with an electric drill and suitable extension with the distributor removed, vary the speed and see what happens to the oil light.
Mike Hammond
Old November 29th, 2004, 04:35 PM
6" extension with a 12mm socket works best! And turn clockwise! Be sure to mark the distributer in relation to the engine and the placement of the rotor before you pull it off. It is a ton easier if you pull the upper radiator hose off of the engine. And don't ask why I know all this! I have been fighting low oil pressure for weeks know!
Old November 30th, 2004, 12:47 PM
mikeslandrover
Mike Hammond
Best of luck with your oil pressure.
I think I've finally cracked my fuel supply woes.
Mike Hammond
Old December 2nd, 2004, 01:37 AM
pendy's Avatar
pendy
jim pendleton
89'd90
If you used a cheap filter without a pressure baffle it will bleed the system down while sitting.
JP
legend in my own mind
Old December 2nd, 2004, 01:39 PM
mikeslandrover
Mike Hammond
Sometimes the pump can drain whilst emptying the sump during an oil change. Not good....
Mike Hammond
ht, start
Oil Light milli Defender Technical Discussions 10 August 30th, 2005 05:32 PM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
D-110 Oil Light Flickering?? sharknet Defender Technical Discussions 12 May 27th, 2004 10:06 AM
