The De-TD5ing of a 110? - Defender Source
Old March 1st, 2011, 07:03 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I know this sounds like a sin, but I need to get rid of all the wires and computers, I only have the 200tdi going in it.
The body is an early (1999) TD5 and I need to know which harness would work best, a 200tdi or 300tdi harness.
I'd like to use the gauges if possible, I included a pic of the gauges.
ID:	36316   Click image for larger version
Old March 1st, 2011, 07:11 PM
alastair's Avatar
alastair
AJS
84/94/95/2013
I've got no help to offer; I just wonder how many "how much do you want for the _ _ _ _ _ " posts appear before someone actually answers your questions...
Old March 1st, 2011, 07:15 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I may try and trade it for what I need.
Another ?
whats the difference between a LHD and RHD harness?
Old March 1st, 2011, 07:20 PM
alastair's Avatar
alastair
AJS
84/94/95/2013
Another ?
You mean the main harness? I don't imagine there is a difference at all; though I don't know for sure. When we re-wired my 200tdi we did it from scratch: It really is a very basic set-up.
Old March 1st, 2011, 07:31 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Yeah, the main harness, the engine is pretty simple.
As far as LHD and RHD harness, I didn't think there would be a difference either, but I saw a LHD TD5 harness for sale on Ebay UK
Old March 1st, 2011, 07:45 PM
stephen can sell you a 300 tdi engine harness that will plug into the main harness and use the td5 gauges. The 300 harness will work on your 200 with the exception of the coolant sender which should be easily overcome. I have one but you cant have it.
Old March 1st, 2011, 08:51 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I would just use what you got and hunt n peck the needed wiring. You can even remove the excess.
http://www.reedx.net/landrover/mods/2002dash/index.htm
Will get you the information you need.
legend in my own mind
Old March 1st, 2011, 09:48 PM
alastair's Avatar
alastair
AJS
84/94/95/2013
I agree. If an idiot like me was able to re-wire my 200tdi 90 (albeit with some skilled help) it really is straightforward.
Old March 2nd, 2011, 09:56 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I guess if I just can all the excess, it would be simple enough.
Old March 2nd, 2011, 11:01 AM
I would seriously consider sourcing a TD5 if you have everything else!
I'm here for the D's
diesel_jim's Avatar
diesel_jim
Jamie Austin
Older Tdi harness's arn't much different between LHD and RHD. i've heard that you can just "flip over" the loom and everything reaches and fits.
RoW (Rest of world) defenders had that Td5 electronic dash pod but connected up via the "older" Tdi spec loom (but beware... it'll have Td5 type plugs & sockets)
I've got the Td5 dash-to-Tdi-type-main-harness loom part number at home, will post it up later.
Old March 2nd, 2011, 09:25 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Jim, of you want the TD5 stuff let me know, I really don't feel like dealing with all the extra wires. I got it all out tonight, The computer and fuse box under the seat, and everything else. I think a 300tdi or even a 200tdi would be much simpler.
As far as keeping the TD5 harness, what do you do with all the ECU wires?
Old March 3rd, 2011, 05:31 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
PM sent!
Old March 3rd, 2011, 06:43 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The LHD and RHD harness are different but have known people that have successfully swapped them with a bit of making your own connections here and there. You can use the electronic dash but will have to make changes to the water temp sending unit and get the newer version, green colored. There is a great write up on www.landroverexpediton.com. or www.retroanaconda.com. If you want to get a harness that has the changes made to it you can use Part number YMG109260, However it is a bit expensive. You will also need to get a spedo transducer, YEB100530, if you want to use the Td5 spedo. I know it will work on the R380. You should have the wires needed unless they cut them when they removed the engine etc. (If your truck didn't come with the trans) You could also get an engine harness that should hook up to the Td5 loom, YSB001281. The main wiring harness I used was, ymc000470, from my understanding this was the last harness used for the 300 Tdi's in the Td5 configuration.
I do not know if the engine security system will effect anything. It all goes through the ECU so probably not. You should have a module under the dash pod with two connectors, one Gray and one Green. I would disconnect them and see what happens once you have everything else figured out.
I tried to get all my harnesses to be plug and play but have found there are so many variations that it is a hard thing to do. My Chassis harness did not have the connector for the rear lighting. The wires were present but not hooked up. I will have to make a connector for that. So I think you will have to make some connectors on some things no matter what you end up doing.
Land Rover 110
110, td5
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
