the best way to remove paint - Defender Source
Old September 20th, 2009, 08:46 PM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
What is the best way to remove paint from old wings (aluminum body parts)?
Old September 20th, 2009, 08:50 PM
brake fluid, you should see under my clutch pedal.
Old September 20th, 2009, 08:51 PM
Paint stripper... They gel type. Just make sure that it is safe on Aluminum. I used some old stuff my dad had on my Black 5 Bar to change them to plain Aluminum. It worked fine, no damage to the Aluminum.
Old September 20th, 2009, 09:34 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
gel airplane stripper and a BBQ cleaning brush worked great for me.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old September 22nd, 2009, 12:53 PM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
x2 on the airplane stipper. Made for aluminum and will not etch.
Old September 22nd, 2009, 01:27 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Soda blasting worked like a charm for me and can also be used to de-grease parts or engine.
Pat
Kirk Lazarus, Tropic Thunder
paint
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
remove front diff? scoloco Defender Technical Discussions 31 April 7th, 2005 03:23 AM
Paint Color/ Paint Code little black duck Defender Technical Discussions 3 March 16th, 2005 05:30 PM
Paint Code? Trigger Defender Technical Discussions 4 June 17th, 2004 01:45 PM
