the best 2.8 Mod ever - Page 2 - Defender Source
Old January 31st, 2012, 06:00 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Does it fit along side the radiator, like in a single row or is it infront of the radiator? I know they have uprated intercoolers that fit the stock location along side the main radiator too.
If you get a bigger one that goes infront of the Rad you will be able to keep those EGT down so you could continue to run the 3/4 to full turn I imagine. Do you have AC?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 31st, 2012, 08:06 PM
Santiago
Santiago Gigola
Daniel Marcello,
Assuming it came from Pendy I bet Overlander's IC is the full-width one. I have the original size but uprated IC from Brunel (or Allisport?, I don't remember where I bought it).
The interesting thing about these engine tweakings is that you need to try for your own. I have the same engine as Overlander BUT my IC is different so I doubt I can just apply Overlander's recipe for the full-throttle screw in the injection pump and expect exactly the same result ..........but I can try.
Cheers,
Stgo
Old January 31st, 2012, 09:01 PM
My radiator is not a full width/in front type. It is in stock location beside the radiator, but I think it's thicker than normal. It's shiny aluminum (not sure if stock is same). I do have A/C, so my condensor is in front of radiator and IC.
Old January 31st, 2012, 10:27 PM
I thought that 1300 or so was the upper limit of EGT that one would want to see.
Originally Posted by Overlander
. With just the 1/2 turn, I'm still rolling on the highway at 70mph at around 1k degF, and going up long inclines, hitting around 1500-2000k degF. Running around town, I'm still at 900 degF. I clearly have room to add a little more heat.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 31st, 2012, 11:12 PM
ini88's Avatar
ini88
Daniel Marcello
Originally Posted by Santiago View Post
Daniel Marcello,
Cheers,
Stgo
I agree. Those engines are all different. And im in now way offering a way to increase power because It could get out of hand real quick.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 1st, 2012, 06:14 AM
Santiago
Santiago Gigola
Overlander,
Ups, sorry for stepping in and adding confusion. So your IC is pretty much similar to mine (at least in width), another reason to give that screw a try.....).
Old February 1st, 2012, 07:49 AM
Don't know what I was thinking when I wrote that! It was late. I hit around 1100-1150 on long climbs, which I tolerate for short durations. 1200 is my No Pass number.
Mark Kellgren
KM4BOR
Old February 1st, 2012, 08:14 AM
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
On line at Garrett turbo website the fine print says 1330 for most turbos. They do have high performance ones that will handle 1500. I would be more worried about the aluminum head and head gasket.
Old February 20th, 2012, 05:43 PM
Santiago
Santiago Gigola
Hello Mark,
Any chance you may have a few minutes to take a pic of were you drilled to tap the EGT gauge on the 2.8 exhaust manifiold? I plan on doing it soon!
Cheers,
Stgo
Old February 21st, 2012, 04:08 PM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Santiago, any idea who to contact in Sth America for parts ?
One of the fella's on AULRO has had a runaway with his 2.8 and he needs things like injectors.
I think he's ordering pistons, etc from M&D, but the injectors are up around 150 pounds each and the one in the bad cylinder is stuffed, with the other three not testing well.
Surprisingly the head and valves test OK.
The 2.8 uses the same main body as the 300Tdi injector but the nozzles are different.
Old February 21st, 2012, 04:20 PM
I'm going out in the parking lot to take that pic right now.
Old February 21st, 2012, 04:25 PM
here you go. Sorry for delay.
Mark Kellgren
KM4BOR
Old February 22nd, 2012, 08:43 PM
Santiago
Santiago Gigola
Hello Rick,
I found out that information for Overlander (I think it was for him, not sure) a few months ago...mmmm, last year I believe it was. Let me see if I can find it and I will copy the link here. Basically the answer is YES, you can buy the parts here, in Buenos Aires for example. The shop I spoke with can deliver the parts to anywhere in the world.
Cheers
Stgo
------ Follow up post added February 22nd, 2012 10:43 PM ------
Thank you Mark!! Thanks a lot.
That was fast.
Cheers,
Stgo
------ Follow up post added February 22nd, 2012 10:45 PM ------
Did you drill an tap it yourself or had somebody do it?
Easy? Any tricks?
Old February 22nd, 2012, 09:00 PM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Thanks mate, very much appreciated.
It's for unimformed (Sergio) and he started a thread here http://www.aulro.com/afvb/technical-...death-oil.html
He unfortunately overfilled it and had a runaway.
It scored # 2 bore and the injectors are cactus but at last the head's OK.
Santiago
Santiago Gigola
Rick,
This is it:
http://www.defendersource.com/forum/...t=29928&page=2
Let me know if I can help you with something else down here (Mendoza, Argentina).
Cheers,
Stgo
Old February 22nd, 2012, 09:07 PM
Santiago, yes I drilled and tapped myself when i had the turbo off. very easy
Mark Kellgren
KM4BOR
Old February 22nd, 2012, 09:08 PM
Santiago
Santiago Gigola
How difficult to get the turbo out?
Just undoing the nuts and bolst?
Old February 22nd, 2012, 10:23 PM
yep, and the outlet/ inlet hoses, and boost line. way less intimidating once you've done it once. recommend getting a new orange o ring for outlet elbow and a new metal gasket for turbo ( yours may or may not have one) before starting.
Mark Kellgren
KM4BOR
Old February 22nd, 2012, 11:45 PM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Thanks again.
Old February 23rd, 2012, 08:09 PM
Santiago
Santiago Gigola
Anybody knows what type of probe I need to buy? I recall somebody mentioned (in this forum?) that for the 2.8 TGV you need to buy a "K" probe, whatever that means....I will probably buy the ones made by Auber instruments (http://www.auberins.com/index.php?ma...roducts_id=139). I just need to knmow which probe. Perhaps I will ask in another (specific) thread but if anybody who has done it knows I will apreciate your guidance.
Stgo
mod
2.8 and snorkel pcarey Defender Technical Discussions 16 July 22nd, 2010 03:59 PM
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
I need to mod! rustydefender Misc. Chit-Chat 4 July 27th, 2005 10:56 AM
D 90 Ex mod soft top for sale k4rovers For Sale - Vehicles 0 December 31st, 2004 12:11 PM
best 4x4 mod? snuffer Misc. Chit-Chat 28 August 16th, 2004 03:10 PM
