That freakin drop-arm ball joint.... - Page 4 - Defender Source
Old April 12th, 2013, 03:49 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Hmmm, this would have been a big help!
http://www.island-4x4.co.uk/steering...25-p-7073.html
and this tool wold definitely do the job, bit pricey though.
http://www.hnjengineering.co.uk/page...nj7000000.html
Originally Posted by rover4x4 View Post
Probably a horrible idea but why not loosen the big nut and drive a few miles?
Knowing my luck it would fall off at the most inopportune time, causing crashes, death, destruction and the associated grief that accompanies that sort of thing.
------ Follow up post added April 12th, 2013 09:10 AM ------
Because satan himself created the corrosion and force that holds this on ...
Yep. Heat, puller & bashing with an engineers hammer (proper tool no claw hammer used here) to free the thing.
Buying a new drop arm still means you have to get the old one off.
Mike Hammond
Old April 12th, 2013, 04:06 AM
mikeslandrover
Mike Hammond
just got to mess with the pre load screw on the top of the box.
Mike Hammond
Old April 12th, 2013, 08:31 AM
Not to start a flame out but I think the disco design with a removable tierod end is a better setup/superior design/ and an easy conversion to make. Just requires a bracket for the steering stabilizer so it can stay in the same place.
Old April 12th, 2013, 08:36 AM
Great suggestion, but the ball joint should never be left to get so janky. They're cheap enuf that you can do them every few years. Fortunately I haven't encountered one that was as bad as what mike describes. I woulda thrown that whole shyte in a box and sent it to Meridian, and poached a drop arm from one of you freeks.
Old April 12th, 2013, 08:37 AM
mikeslandrover
Mike Hammond
I might be wrong but I think welding steering components is an MOT no no this side of the pond, but agree the disco design is much easier to swap when the ball joint goes.
Mike Hammond
Old April 12th, 2013, 09:07 AM
No welding, all factory bolt on parts. Just replace drop/pitman arm off steering box and use disco drag link. The steering stabilizer bracket is an aftermarket bolt on.
Just use the smaller bracket and u bolts from a kit similar to this one-this kit is for the oversized "sumo" sold by Gwynn Lewis.
http://www.ebay.com/itm/Steering-Dam...#ht_1638wt_677
Way mo betta
Old April 12th, 2013, 09:26 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Those damper relocation kits(esp the stem-to-stem style) are stupid easy to make. A few bucks at a metal supply shop and a few minutes with an angle grinder and drill and you're good to go.
Old April 12th, 2013, 11:18 AM
mikeslandrover
Mike Hammond
Good stuff.
Mike Hammond
Old August 3rd, 2014, 09:40 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Resurrecting an old thread:
Many moon ago I bought a rebuild kit for the drop arm ball joint. I am finally attempting an in situ rebuild and so far so good. The bottom socket, ball joint, spring all came out as expected. I haven't yet tried to push out the top socket but that looks like it will be a major pain. Maybe just clean up with old one still in the arm and keep on keep on?
What's odd to me is the extra bits that came out along with the ball. The FSM refers to the parts (circle in red) as a retainer- I assume they were once a single piece. My rebuild kit doesn't have this extra retainer and I don't see the part with the pictures of other rebuild kits online. Since I can't understand what this extra retainer is supposed to do, nor do I have a new one, should I just put this thing back together without worrying about this extra bit?
-mike
Name:	Ball joint pic1.jpg
ID:	100058   Click image for larger version
Name:	Ball joint pic2.jpg
Name:	Ball joint pic3.jpg
Old August 4th, 2014, 07:12 AM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Hi Mike,
the retainer is not necessary.
Please have a look at this: http://www.defendersource.com/forum/...5&postcount=17
kind regards
Kurt
Old August 4th, 2014, 10:08 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Danke Kurt!
That tool you've made is really cool and your cosmetic improvements are inspirational. Thanks for the link! I look forward to following more.
-mike
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
Drop arm! TwisteD90 Defender Technical Discussions 9 July 19th, 2005 09:27 PM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
