That freakin drop-arm ball joint.... - Page 2 - Defender Source
Old September 19th, 2006, 03:38 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Exchange basis..... that would work for me actually. Though I'm not sure my current one would be an acceptable core. The top ring on the lip for retaining the rubber boot cracked off.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 20th, 2006, 05:56 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Originally Posted by D90user
Randy- it is super easy as log as you can get the bottom cup out. but if you have time i'm sure you can find a way
Yeah I see what you mean!!! Once I removed the circlip the ball joint pieces almost fell out except for the bottom cup (socket). Nothing but powdered rust. And in typical LR style, the bottom socket is actually on top???
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old September 20th, 2006, 08:52 PM
redrover
Guest
Posts: n/a
Steve the failures were not on land rovers. Both were on jeeps with large tires. On one the cast broke . On the other the arm was loose. After removing pitman you could see stipped splines. The box splines were fine. The arms look very sililar to ours. Cant hurt to carry amd maybe get home.
Old September 20th, 2006, 09:07 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
good to know JP, I have never heard of a rover one failing completely... although when I took mine out last time I could see how it is possible
Old October 23rd, 2006, 02:09 PM
Hans's Avatar
Hans
Hans Haase
Back to this question, new drop arm in hand. What size nut is that where the drop arm bolts to the steering box? I've got a gear puller ready when I get the nut off, just need to know what size wrench it is.
-Hans
My oil line fix
Old October 23rd, 2006, 03:02 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
34mm
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 23rd, 2006, 03:05 PM
Hans's Avatar
Hans
Hans Haase
oh, good. I think I have that socket in storage. Will check before I go to work.
Then, I cross my fingers about getting the thing off at all.
-Hans
My oil line fix
Old October 23rd, 2006, 06:38 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I had to use a puller and some heat to get mine off.
Old October 23rd, 2006, 08:22 PM
Hans's Avatar
Hans
Hans Haase
I've got the puller and torch ready to go, tomorrow I'll give it a whirl and see what I break.
-Hans
My oil line fix
Old October 24th, 2006, 01:15 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
partialhijackalert: Is this drop-arm ball joint the same style as Range Rover classics? IIRC, it is...
Old October 24th, 2006, 01:22 PM
Hans's Avatar
Hans
Hans Haase
I believe so, yes. But not 100% sure.
Attempt #1 at removing the arm: Failure of the puller, teeth got goobered up.
Also, I found that 1-5/16" sockets fit that nut perfectly.
-Hans
My oil line fix
Old October 25th, 2006, 01:57 PM
Hans's Avatar
Hans
Hans Haase
Tried again, nice new puller with the cage to prevent slipping off. Broke a tooth off the puller.
I give up, $120 in broken tools now. Mechanic time.
-Hans
My oil line fix
Old May 12th, 2007, 08:28 PM
Andrew Vick
Andrew Vick
95 D90
OK. Time to resurrect this thread. I've got a drop arm rebuild kit, and if I understand JP correctly, I've got to remove everything up from the underside? It seems like I have to get the ball joint and the top cup out by tapping through the hole in the bottom cup. Then go from the top and tap out the bottom cup. It ain't budging so far, so tomorrow it gets heat.
Am I missing anything?
Upon further reflection, it seems that everything has to come out through the bottom. The spring, cap and circlip go on last from the underneath, and that pushes everything up. Is that right?
Old May 12th, 2007, 09:12 PM
Hans's Avatar
Hans
Hans Haase
Yep, that is correct. All the guts drop out from the bottom, and go back in the same way. The kit should have a diagram of the order to put them all back in.
Just be careful, as there is a fairly strong spring in there, so make sure you got some goggles on when you put out the ring. Putting it all back in can get a bit tricky, since you have to compress the spring again to get the cover back in place.
Good Luck!
-Hans
My oil line fix
Old May 13th, 2007, 07:58 AM
Andrew Vick
Andrew Vick
95 D90
Awesome Hans. Thanks for the confirmation. The spring and plate fell right out. I'm going to try the caulk gun/socket press as shown in the tech section. Should work..............
Old February 6th, 2010, 04:49 PM
scoloco's Avatar
scoloco
'94 D90 ST
-Hans
Super thread resurrection. Time to replace my ball joint, I sort of have a kit albeit w/o instructions. I took the old ball joint apart from the bottom, all came out nicely except the upper cup, which seems to be in there pretty tight. Pitman arm still on the truck. Need to make sure I try to bang/push it out the correct way.
Does it go out from the top or the bottom (bottom means it follows everything else out)? Or does this piece need to be drifted out the top? I'm assuming the former and it comes out the bottom.
TIA
Old February 6th, 2010, 07:27 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
I went through this exercise a few years ago. I went to Autozone and bought a puller with a lifetime guarantee. It broke. So did the second one. I took the steering box off and trotted down to the machine shop. It broke the guy's press. I ended up buying a used box for $100, complete with arm and functional ball joint.
John Karlsson
Hope Valley, RI
Old February 6th, 2010, 09:20 PM
Hans's Avatar
Hans
Hans Haase
All the parts come out the bottom, nothing comes out of the top other than the rubber dust boot.
-Hans
My oil line fix
Old February 7th, 2010, 05:54 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I also want to replace the ball joint, but I am also having difficulty removing the pitman arm. I have beat on it, pulled on it blastered it. Am currently driving with the nut one turn loose hoping the jarring will loosen it up. any other ideas? Afraid to use heat and ruin the steering box seal.
Old February 7th, 2010, 07:53 PM
scoloco's Avatar
scoloco
'94 D90 ST
I'm still working on the upper cup with the pitman arm still on the truck and still no luck. Looking to get some heat tomorrow to see if that will make a difference.
This may help out getting the pitman arm off...
http://www.defendersource.com/forum/...30&postcount=8
Goodluck!
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
Drop arm! TwisteD90 Defender Technical Discussions 9 July 19th, 2005 09:27 PM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
