TF RTC Steering Dampener? - Defender Source
Old November 20th, 2010, 08:55 AM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
My OME steering dampener is showing signs of wear and it's time to go shopping. I was just going to replace it with another one but then I came across this bling-ish little item:
http://lucky8llc.com/Products.asp?ProductID=2399
Was wondering if anyone has used this and what the advantages/disadvantages might be? I can't see where snapping the steering wheel back to center on the highway quickly would be particularly safe and/or helpful but this could come in handy in some off road situations. It would both work against and with the steering pump so I'm not sure if it extends life, causes premature failure or does nothing. I'm running 255/85R16's for reference. Thanks, in advance, for your input.
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old November 20th, 2010, 12:33 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I cannot see it being a bad thing, except... having one fitted will mask other issues and you would want to remove it every few weeks to make sure it is not preventing you from noticing other issues.
If once my castor is corrected my self-centering does not improve enough I would consider trying one. However, I generally have things apart every few weeks anyway and I'm probably the most picky person out there when it comes to handling.
Old November 20th, 2010, 06:38 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I think I'd give one a go on the RRC if they had the proper mounting style.
Unknown Author
716-898-8153
Old November 20th, 2010, 09:38 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
How long did it last ? I have a Bilstein and the pulling on one side is making me crazy. I was thinking about OME but this can be interesting.
- Charles Eames
Old November 21st, 2010, 11:28 AM
jaygoss's Avatar
jaygoss
Jay Goss
Not quite sure- was installed by previous owner. Just had the panhard rod bushings (and every other bushing in the drivetrain) installed to address the infamous "death wobble". There's a shimmy when I hit bumps at highway speeds. I may be expecting too much but another $80 for a new steering dampener is a drop in the bucket compared to what I've put into this money pit since I've acquired it!
I'd check into it but my understanding is the Bilstein products are an upgrade to original equipment with regard to handling but they aren't as heavy duty as the OME stuff, which is necessary if you've beefed up your suspension, installed bigger wheels, etc.
Old November 21st, 2010, 12:27 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Its your swivel pin bearing preload.
Old November 21st, 2010, 02:36 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
That OME steering dampener was put on when I put the OME lift on - roughly Fall of 08.
Semper Fi!
Old November 21st, 2010, 08:19 PM
jaygoss's Avatar
jaygoss
Jay Goss
Thanks!
------ Follow up post added November 21st, 2010 06:21 PM ------
Thanks Steve- I'll check that. Sounds like my dampener has relatively low miles/off road use so this would make sense
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
Steering problem! TwisteD90 Defender Technical Discussions 3 June 2nd, 2005 02:55 AM
» Defender Registry
109
kraison
'94 D90
cbcarlino
Add your Defender
