Testing Temp Sensor - Defender Source
Old May 3rd, 2016, 01:43 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Testing Temp Sensor
I need to change my temp sensor on my 200tdi. I was thinking before removing the old one I could connect the new one and drop it in 180 degree cup of water to make sure it is compatible with the early 80's original gauge. Anything I might be missing or not thinking about here?
Old May 3rd, 2016, 01:47 PM
If it is a Defender 200TDI sensor, it will be correct. All Defenders use the same range gauge. If it is a Discovery 200TDI sensor, it will not be correct.
Your test sounds fine. Only insert the tip...... and ground the threaded part.
Fuel Temp Sensor engine code Tim Scully Defender Technical Discussions 0 January 9th, 2008 08:34 PM
Erratic Oil and Temp Sensor Jon_Winningham Defender Technical Discussions 10 March 30th, 2007 09:27 PM
temp sensor? mattdh Defender Technical Discussions 6 June 16th, 2006 07:00 PM
fuel temp sensor mattdh Defender Technical Discussions 2 May 13th, 2006 08:59 PM
Oxygen Sensor Testing Antonios Defender Technical Discussions 6 April 1st, 2006 10:24 PM
