Terrafirma Shock Towers - Defender Source
Old December 10th, 2012, 11:56 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Has anyone put these in stock D90? Got a set while back and finally getting around to putting them in as replacement from stock towers and seem not to fit. Top part of tower hits on well cover. Was looking around at sellers and no one mentions requiring modification.
Would appreciate any input..... Rather not have to cut well cover.
update with some pics..... its minimal but will not line up with securing ring due to well cover.....
ID:	62487   Click image for larger version
Old December 10th, 2012, 12:02 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I have a set on my 110. They are handed. Make sure you have them on the correct side. Mine does not hit the well covers.
MUDSUX
Old December 10th, 2012, 12:06 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
X2 flip them around 180 if they are like equipe it should fix the problem
Old December 10th, 2012, 12:17 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I removed the covers and there wasn't enough space to put them back on.
Old December 10th, 2012, 12:22 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
swapped to other tower in case different and it is closer fit but still rubbing on cover. Going to hammer back well cover gradually see if I can make the approx 1/2"+ needed.
Old December 10th, 2012, 12:24 PM
Notice they are galvanized. I have Paddocks units http://www.paddockspares.com/shock-a...alvanised.html No problems fitting them
Old December 10th, 2012, 12:42 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Nice price on those.... they're like originals, terrafirma are a bit wider and non-tapered on top
Old December 10th, 2012, 12:48 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Put a set on my 85 D90, had to swap and change sides to get them correct, but once I had it correct fits with no touching the cap or inner fender.
Wish now I had got the shorter version for the 2" lift, but C'est la vie
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old December 10th, 2012, 01:42 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Seems after swapping sides as recommended and various strategic hammer blows to inner fender cover they will fit. Tight fit for sure!!
Thanks all for the guidance!
USLandy's Avatar
USLandy
Andrew
defender 90
I put them on my 90. If I remember correctly there should be at flat portion of the circular base and that should face the engine bay
Old December 10th, 2012, 06:40 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
There is a square edge on base and does seem to have to face engine, even then rubs on top by engine bay shock opening. Hopefully drivers side will be easier fit.
Old January 6th, 2013, 04:45 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Does anybody know why there are two holes drilled at 45 degrees on the top? Are those functional? I thought they might be there so you could slip a bolt across the top to mount eyelet shocks. I have Bilstien 7100s and I would get these towers over the D2 towers if they would accept an eyelet shock. Any thoughts?
Front Terrafirma Shock Towers, Retainers Wolf Fabrication For Sale - Parts 9 December 30th, 2011 07:05 AM
Terrafirma Shock tubluar towers evilfij Defender Technical Discussions 0 April 12th, 2010 05:20 PM
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
16x10 steel wheels/DiscoII shock towers WillT Wanted 6 August 2nd, 2005 01:12 PM
Galvanized stock shock towers... dmarchand For Sale - Parts 1 May 22nd, 2004 04:28 PM
