Terrafirma RTC Damper - Defender Source
Old May 27th, 2012, 03:11 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Has anyone on here used this? Is it worth the money? Any good writeups on it yet?
Thanks in advance.
http://www.roversnorth.com/p-18551-t...-90110130.aspx
Old May 27th, 2012, 05:15 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
FWIW it's cheaper through Lucky 8.
I got one for my 110 with 255/85s and 2" lift. I have been running it for probably about a year now. I do like how it aids in getting back to center. My major issue with it is that I don't have power steering so it takes more effort to get the steering wheel around. Might not be great for non power steering applications. Overall it seems to be a good product though.
Old May 27th, 2012, 09:21 PM
Rosproline157
Matt Oaks
1992 Defender 90
Thanks! I will shoot Justin an email.
Old May 27th, 2012, 11:58 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I thought that the general consensus was that if you needed a RTC there was something wrong with your steering, that is unless you are running giant tires.
Old May 28th, 2012, 02:02 PM
USLandy's Avatar
USLandy
Andrew
defender 90
I put one on my 90 about 2 months ago and I like it. There isn't too much resistance against turning and it comes back to center. I don't feel to much power added, if anything it just feels smoother.
Old May 28th, 2012, 02:33 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
The more highway travel I do the more I consider fitting one. The flex in my tire sidewall makes steering feel a little loose (and I've eliminated every other potential cause) and when spending long times on the highway for days in a row having a small amount of centre bias could reduce driving fatigue. For low speed/offroad use I wouldn't consider one; but when driving 10-14h a day it is one of three modifications I'm considering. Another is a remote clutch booster (knee pain is a problem) and a throttle lock.
Old May 30th, 2012, 08:52 AM
Rosproline157
Matt Oaks
1992 Defender 90
Any lift? What size tires?
Old May 30th, 2012, 11:00 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Yea I have a 2" terrafirma lift with the cranked radius arms. I run 265/75 tires. Also have RTE heavy duty steering rods
TerraFirma Kits / Sliders On Sale SafariHP The Vendors Loft 14 October 20th, 2011 05:18 PM
Terrafirma Anyone? Cred Defender Technical Discussions 6 September 23rd, 2009 04:13 AM
OME Steering Damper Nut Sergeant_V Defender Technical Discussions 2 September 10th, 2006 04:16 PM
Questions regarding Steering damper Mark M Defender Technical Discussions 2 November 20th, 2004 02:45 AM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
