Terrafirma rear trailing arms bushings - Defender Source
Old October 18th, 2014, 11:53 PM
Jwillia's Avatar
Jwillia
Justin
87 ROW build in progress
The stock bushings seem to be too small. Does anyone know where I can get the specific ones for these? I wrote Atlantic British (were I purchased them) with no luck. They don't carry them.
Old October 19th, 2014, 12:24 AM
Lucky8 maybe?
Old October 19th, 2014, 12:58 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Which trailing arms?
Old October 19th, 2014, 01:02 AM
Jwillia's Avatar
Jwillia
Justin
These
Old October 20th, 2014, 05:14 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi did the arms come with poly bushes?
If so they will have moulded "end caps" on the bush they will push through in a vise
If your stuck drop me a pm and I'll check with uk suppliers
Regards
Gren
Old October 20th, 2014, 05:18 PM
Jwillia's Avatar
Jwillia
Justin
Regards
Gren
They didn't come with anything. I was considering turning the stock ones down in a lathe to fit, but your idea sounds better. Any help would be appreciated.
Justin
Old October 21st, 2014, 11:17 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Justin
I've spoken to sales @ John Cradock they are a terrafirma dealer, the part number you have is TF509 they take standard axle set polybushes
part number NTC1772P axle side 3.74ea
part number NTC9027P chassis side 20.65ea
the P denotes it's a polyurathane bush as opposed to an OE metalastic bush
you should be able to pick these up locally with the above part numbers
hope this helps
regards
Gren
Old October 21st, 2014, 11:42 AM
Jwillia's Avatar
Jwillia
Justin
Hi Justin
hope this helps
regards
Gren
Thank you!
Old October 21st, 2014, 11:51 AM
The Dro
Dro
1988 Ninety
Call Justin or Erik with those part numbers.
http://lucky8llc.com/Offroad.aspx
Old October 21st, 2014, 12:14 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
We have them as well...
bushings
Offset Radius Arms and Rear Trailing Arms OBXrover Wanted 0 September 28th, 2013 01:36 PM
RTE trailing arms and bushings Jake1996d1 For Sale - Parts 22 September 9th, 2012 08:27 PM
Would cranked terrafirma front & rear trailing arms make a huge difference? Neil McCauley Defender Technical Discussions 19 August 20th, 2011 08:03 PM
Bolt size for Radius Arms and Rear trailing arms Rugbier Defender Technical Discussions 5 May 29th, 2009 10:23 AM
Rockware Trailing Arms w/ good bushings lwg For Sale - Parts 1 January 9th, 2005 04:06 PM
