Terrafirma Big Bore - Defender Source
Old July 7th, 2011, 03:37 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Terrafirma Big Bore
Any direct experience with these? Chinese crap... or a good deal?
Thinking of using them on the ambulance as my shocks are shot and I could use more dampening.
Old July 7th, 2011, 04:03 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I just had a 110 in the shop that had the full TF suspension installed. It seemed OK and had plenty of dampening. Actually seemed a little stiff for my liking. They looked to have been at least a 2-3 inch lift so the stiff may have been more spring related. They were all new (ish) though so no word on long term but did not seem like "Chinese crap".
Matt Browne
Old July 7th, 2011, 04:04 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've run them on my heavy 110 for the past year with great results so far. I know of a heavily used Disco that has also run them for a while and he likes them. They seem like a good shock for minimal $$.
And yes, they are "stiffer" than other shocks, but I am fairly top heavy and like 'em that way.
Semper Fi!
Old July 7th, 2011, 04:31 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
If that IS your headshot you use for an avitar then, yessir you are a little top heavy..... might want to tie the old shocks around your ankles for ballast.
Matt Browne
Old July 7th, 2011, 07:30 PM
D90user's Avatar
D90user
steve
Good Info. Thanks.
I could definitely use stiffer/more dampening on the ambulance. I'm keeping the springs the same (front: LR HD & rear: OME 754) they are a good combo for me.
For the same price as OME shocks I think I'm willing to give them a shot.
Old July 7th, 2011, 08:39 PM
Please dont buy Chinese products
Old July 8th, 2011, 04:07 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Yeah, that's practical advice.
Tony
1984 110 "Smokey" (sold)
Old July 8th, 2011, 05:26 AM
Wolf Fabrication
Sterling Archer
'08 D3
And sadly nearly impossible. Kinda like saying don't buy a British car.
Semper Fi!
Old July 8th, 2011, 06:18 AM
Not quite
Old July 8th, 2011, 08:02 AM
Agree. I will own nothing other than high quality British vehicles
Old July 8th, 2011, 08:37 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
So you don't own a car then?
Old July 8th, 2011, 10:54 AM
D90user's Avatar
D90user
steve
I'm right there with you. I'd pay a bit more for a non chinese product, any suggestion?
The reality for every day life is almost impossible though... where do you think most of your computer is from?
Old July 8th, 2011, 11:00 AM
Abrooks's Avatar
Abrooks
Tony Brooks
I believe Fox shocks are made in the US.
Old July 8th, 2011, 11:53 AM
The Dro
Dro
1988 Ninety
Rancho shocks are Made in USA
Old July 8th, 2011, 01:06 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
The Rancho's I've used and installed on clients Rovers ride like POOP! The TF's seem to be okay so far but I have no long term results. OME still seem to be the best bang for the buck. If you are look'n to stiff'n it up abit then just change OME part #'s. If you are still using the factory shock points than I would go with something like N25 for the rears and N73 for the fronts. They are the perfect size for what Rover and lift you have. Just my $0.02.
Old July 8th, 2011, 01:34 PM
D90user's Avatar
D90user
steve
Is there an out of the box Fox shock for standard travel that does not require changing the mounts? Do they last?
I have not had good experiences with Rancho's....
I currently have N44 in the rear and N115 in the front and they are not doing the job... what is the difference for N25 and N73?
Thanks for the input!
Old July 8th, 2011, 04:09 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
I have not tried to fit a set of Fox's to a standard Rover...yet. The OME's that I gave as an option to you are just abit longer and are valved different than what you have now. They seem to firm up the ride and body-roll with alittle bit more down travel when you want to stretch your legs. I don't remember which ones are for what application but they will fit the stock shock locations. Me and one of the ARB rep's were going over the catalogs years ago over some beers in Moab and came up with this combo for clients that didn't have crazy lifts on their Rovers but wanted to eliminate body-roll and give a good ride.
Old July 8th, 2011, 08:47 PM
It would be nice if fox offered a shock that had a pin/eye configuration. I hear a lot of bad things about those heims, looks like the Aussies win......
HELP! Big end bore spec Davis Defender Technical Discussions 10 August 24th, 2015 05:42 PM
hub bore of a Range Rover P38 or Discovery 2 rvrnut110 Defender Technical Discussions 0 November 18th, 2005 05:26 PM
Big Bend Trip tron Trips, Trails and Events 4 November 9th, 2005 10:10 AM
Big Sky Rover mhansen Defender Technical Discussions 2 May 17th, 2005 09:11 PM
Big Dogs lobster Trips, Trails and Events 0 April 15th, 2004 01:34 PM
» Defender Registry
Gruff
Stormer
LRNA04
lrna04
Add your Defender
