Terrafirma 2" lift experiences? - Defender Source
Old October 10th, 2011, 09:54 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I'm looking for some input from some of you out there that have used this lift. I realize every truck is unique but I am guessing someone out there has had a similar experience. I installed the springs, shocks, retainers and tubular shock towers. Now the steering is unresponsive and downright scary and there is a slight vibration when I let off the accelerator and put a load on the drivetrain but only sometimes, it feels like I am driving on asphalt that has been ground down. I talked to a guy behind a desk(thanks Justin) and his ideas just from the description over the phone were check my steering box and linkage and have a look at the drive shaft. The u-joints seem to be solid, there is a little play in the shaft where the two pieces come together so they can slide in and out but I am assuming that is normal? I was under the impression that you could do the 2" lift without the castor correction, could this be the cause of all my problems? I plan to replace all of the steering bushes but the radius arms were not something I was planning on doing. Sometimes you just have to say WTF right? Thanks for any input or suggestions. I have searched the topic and found some info but I am looking for some more specific opinions of what I need to be looking for
Thanks, Jason
Old October 10th, 2011, 09:59 PM
USLandy's Avatar
USLandy
Andrew
defender 90
I can't help you just yet, but come this weekend I'll let you know how my lift kit install goes. I'm putting in all the same terrafirma stuff, +2 medium springs, but with 3 degree castor corrected radius arms and throwing in the bearmach rose joint rear trailing arms. So come sunday I'll hopefully have it all done, and I'll let you know if I have any driving issues. Sorry I couldn't help right now though
Old October 11th, 2011, 01:08 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
So, after doing more reading I think I got the info I need but I am still interested in hearing others experiences with this particular lift and how you have dealt with the different problems that have come up
Old October 11th, 2011, 08:26 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I just put the same on my truck and have been driving it for a couple weeks now. Didn't have any of the issues you speak of. I also added a return to steering damper steering damper (probably not a good idea for manual steering) that you might benefit from.
Old October 11th, 2011, 11:17 AM
texmoto
david summers
99 Discovery II
Sounds like a u-joint may be going bad. May have been marginal prior to lift and extra stress (increased drive line angle) is making symptoms worse.
Yes, the drive shaft should slide in & out. Try greasing the shaft and the u-joints. Make sure you see fresh grease come out of all 4 seals. If not, replace the joint.
Yes, the other feeling could just be loss of camber. But check bushings as well.
1994 D90 ST
2004 DII
Old October 12th, 2011, 12:44 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Back in the spring I installed a OME 2" lift and all new bushings. And like you the first time
I drove it was scary.Then I replaced my (worn out) tie rod ends and rebuilt the pitman arm ball joint.
After that it was better, but still not like it was before the lift. Steering was more "touchy", especially
at speed. After I drove it for a while, including a 3000 mile trip to Utah, I got used to the way it
handles now. It just took a little while.
Hope this help.
Bryan
From 2" to 3" lift... questions TexasD-90 Defender Technical Discussions 23 February 8th, 2011 04:54 PM
2" Lift, how big of tires can I get? TravelerBT Misc. Chit-Chat 6 November 21st, 2008 12:44 PM
front end shudder after increasing lift from 2" to 3-4" rgrrvr Defender Technical Discussions 0 January 19th, 2008 08:35 PM
2" OME Lift Before/After Pics pcscharfe Defender Technical Discussions 5 November 13th, 2007 02:09 PM
Question about 2" lift on NAS D110 Stmpede Defender Technical Discussions 10 April 3rd, 2007 06:12 PM
