Tentioning alt/fan belt on 2.5NA Diesel - Defender Source
Old June 5th, 2013, 09:17 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Taking the old belt off and getting the new belt on seems very straight forward, however my Haynes Manual advises to test and set the tension on the belt. It didn't have further instructions on that as far as I could tell (though perhaps buried in another section).
How do I do this, and is a special tool required?
TIA.
Old June 5th, 2013, 09:22 PM
No, just tighten like any other V-belt. They like to be on the tight side as the alternator has very little wrap.
Old June 5th, 2013, 09:27 PM
josh-man's Avatar
josh-man
joshua
Ok. So one I have the alt pivot bolt loose and new belt in place, just rotate the alt back as far as I can an crank down that bolt to lock it in place?
Appreciate it!
Old June 5th, 2013, 09:33 PM
Appreciate it!
No! There is a deflection spec. Not sure what it is. Tight but not as tight as you can.
Old June 5th, 2013, 09:38 PM
josh-man's Avatar
josh-man
joshua
Is this gonna be a trial and error thing for me then? I've never replaced a belt so bear with me on my likely obvious questions.
Old June 5th, 2013, 11:10 PM
No problem I just wanted to make sure you did not mess it up. Over tight kills the bearings.
Old June 5th, 2013, 11:25 PM
josh-man's Avatar
josh-man
joshua
Thx man. Now how to figure out what is too loose vs too tight?!!
Old June 5th, 2013, 11:31 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Don't stress to much, get it all back together with a loose alt bolt pull alternator to where you get about a half an inch of play on the belt then tighten down.
In the NAS repair manual there is a spec which shows how much deflection (ie how much the belt moves on the long part). Not sure on your truck.
Old June 6th, 2013, 03:52 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Too loose is easy. If the charge light is on, too loose. If the belt squeals, too loose.
Too tight? Need to know the deflection speck.
Mike.
Old June 6th, 2013, 09:28 AM
josh-man's Avatar
josh-man
joshua
Thanks Brian. Appreciate it.
Old June 6th, 2013, 10:07 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
you should be able to twist the belt 1/4 turn at the longest run .... i takes time but you get the feel of it
No Mall crawler here
Old June 6th, 2013, 10:27 AM
josh-man's Avatar
josh-man
joshua
OK, seem to be narrowing it down to figuring out how to NOT overtighten!
Old June 6th, 2013, 10:50 AM
Download the genuine workshop manual. It says...
Tighten the clamp bolt and with thumb pressure, check the belt tension between the fan
and alternator pulleys which should be 7 to 9 mm (3/16 to 1/4 in) at the mid-point.
Old June 6th, 2013, 11:15 AM
josh-man's Avatar
josh-man
joshua
Thanks, Red. Comes back to my original question of how to perform that test- is it just a "by feel" test?
REALLY appreciate the assist with this.
Old June 6th, 2013, 11:22 AM
Yes, just by feel. "thumb pressure".
Old June 6th, 2013, 01:13 PM
josh-man's Avatar
josh-man
joshua
cool. I think EVEN I can handle that LOL. Appreciate it!
WTS: 2.5na complete Diesel engine $1500 headdamage For Sale - Parts 0 January 10th, 2009 12:20 PM
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
WTS: 2.5na diesel engine (in CANADA) headdamage For Sale - Parts 2 April 1st, 2008 04:36 PM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
