Tensioner Pulley rebuild? - Defender Source
Old March 9th, 2010, 08:49 AM
The bearings on my tensioner pulleys might be due for renewal. It appears that they are press fit into the arm and the pulley is pressed onto the bearing. has anyone evr tried to fix these things? New ones are about $200 compared to 70 for the bearing. 4.2 serp belt loob
Old March 9th, 2010, 09:20 AM
if it is the same as the tdi unit (it probably is) I got my bearing for $12 at a local supply. was able to worry the reatining ring out with a small screwdriver and knock the bearing out and back in with a socket. piece o' cake.
Old March 9th, 2010, 10:07 AM
Agreed you should be able to find a bearing cheap locally. Take it to NAPA once you have it out and they can match it up to something in stock.
Old March 9th, 2010, 11:49 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Yeah, I have a whole bunch of those bearings, I think the cost was around $12.
John C.
Old March 9th, 2010, 01:46 PM
Monkeyboy
Guest
Posts: n/a
Hi Bill,
If the 4.2 serp is similar to the 3.9 and the later 4.0, the pulley / wheel should slide off of the shaft.
There is at least one circlip (I can't rememver if they're on both sides or not) holding the little bearing in the pulley.
On my '94 Disco, this was a normal everyday circlip with holes in it. Get the pliers, pop it out replace the bearing unit and that's it.
On the '97 D90, the circlip had no holes!? Judicious use of a small drill bit and repeat the above instructions...zip-a-dee-doo-dah....quiet pulley.
I took the bearing to the local NAPA and found replacements for something like $8. Yes, I have extras on the shelf.
Cheers,
KAA
Old March 9th, 2010, 03:53 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
pulley
Would this work or is it a POS?
http://cgi.ebay.com/ebaymotors/Dayco...Q5fAccessories
Old March 9th, 2010, 03:56 PM
Dayco is a decent brand and is OEM for the belts on my rovers. Not sure if it is any good for tensioners though.
Old March 9th, 2010, 04:03 PM
Monkeyboy
Guest
Posts: n/a
I'd fix the o.e. pulley and toss an extra bearing in the cubby, that way you know how to do it if you really need to.
Literally might take 10 minutes longer that remove and replace with a new one.
Old March 9th, 2010, 05:38 PM
Originally Posted by Campbell View Post
The tensioner pulley on the 4.2 is a v belt.
Old March 9th, 2010, 05:42 PM
Monkeyboy
Guest
Posts: n/a
Blast. I read this as indicating 4.2 w/ a serpentine set up.
KAA
Old March 9th, 2010, 06:33 PM
Yes well 4.2 is a mashup of v belts and one seep. Easy to mistake
Old March 9th, 2010, 09:27 PM
95 LWB = serp belt
Old March 9th, 2010, 10:39 PM
As in my sig, 93 lawib. Not 95. If I have confused anyone, my apologies. Pulley in question is the v belt tensioner. There are two on this engine. The other flat ribbed belt is tensioned with an adjustable arm on the alternator.
Old March 9th, 2010, 10:59 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Out of curiosity, how did you know that it was time to replace the bearings? I'm getting an occasional squealing from that area and I suspected the pulleys but wasn't sure.
Old March 9th, 2010, 11:36 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
replace bearing
This is a real easy job. Bearing at NAPA is $9.00 and it should take 30 min start to finish. No special tools needed, snap ring pliers, hammer and socket to drive out the bearing. Bench vise to fit it in. Easy DYI project. Save your $200.
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old March 10th, 2010, 12:18 AM
chris snell
Chris Snell
87 Ex-MOD 110
Do you have a part number for the bearing by chance?
Old March 10th, 2010, 07:16 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Bearing is a 6203 on Tdi engine, i guess it's the same on v8.
Lots of pics there:
http://www.landroverfaq.com/viewtopic.php?f=30&t=243
and there:
http://www.reedx.net/landrover/maint...oner/index.htm
- Charles Eames
Old March 10th, 2010, 08:02 AM
Just think it's time. these are OE and seem OK, I'd like to do it for peace of mind.
Ur, not exactly. Maybe if you are referring to the Tdi engine. The one on the RRC has no snap ring or any other obvious means of taking it apart:
Old March 10th, 2010, 09:36 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Bill--the bearing you are referring too is a more specialized bearing as it has an integral shaft/strange configuration. I believe there was a post on this board that referenced this bearing in particular if you can find it. I know a couple people have made there own by turning their own adapter and using a timkien bearing--I'll see if I can find it, but it may take some searching... I may have saved it in one of my archieves, but those are now really big and poorly labeled on my machine...
Old March 10th, 2010, 09:41 AM
Here you go
http://www.defendersource.com/forum/...+bearing+shaft
pulley, rebuild
AC pulley tensioner ini88 Wanted 21 November 22nd, 2010 07:04 AM
tensioner pulley bearing floatflyer Defender Technical Discussions 7 February 1st, 2010 08:54 AM
Water pump tensioner Mike Hippert Defender Technical Discussions 22 March 27th, 2005 12:16 AM
Replacing pulley bearing Campbell Defender Technical Discussions 4 April 26th, 2004 08:42 AM
Need A/C tensioner pulley Campbell Wanted 0 April 24th, 2004 10:19 AM
