tensioner pulley bearing - Defender Source
Old January 28th, 2010, 11:01 AM
floatflyer
Bryan Krill
'95 D90 wagon
Anyone out there have a source and or part number for the bearing on the fan belt tensioner pulley on a '95 nas90 3.9? The LR number for the whole assembly is ERR3767, but I'd to find just the bearing. Thanks in advance for any help.
BK
Old January 28th, 2010, 11:41 AM
Bryan, if you can pull the bearing, any parts store like NAPA will be able to give you a replacement with the right size and seals.
Old January 28th, 2010, 01:08 PM
floatflyer
Bryan Krill
'95 D90 wagon
Charles, thanks, and the same to everyone else. I dug up an older post and found the info I needed.
Old January 28th, 2010, 07:41 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I just replaced the whole thing on my 3.9. RN asked me if I jsut wanted the bearing, as it was less expensive, so they should be able to source.
Old January 29th, 2010, 10:42 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I haven't looked at mine, but if it's retained with the same type of snap ring as on my Disco, when you get the bearing also get a snap ring that you can use snap ring pliers on. Makes it a lot easier to replace next time.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 29th, 2010, 11:19 AM
It is pressed into the pulley.
Old January 29th, 2010, 09:42 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
There is a very good write-up about this bearing change here:
http://www.reedx.net/landrover/maint...oner/index.htm
I'm doing it this week-end, what i did not figured out is
if the pulley is mounted with the circlip toward front
or back .
- Charles Eames
Old February 1st, 2010, 08:54 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Anyone has done this with the a/c belt pulley tensioner ?
- Charles Eames
pulley
AC pulley tensioner ini88 Wanted 21 November 22nd, 2010 07:04 AM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Water pump tensioner Mike Hippert Defender Technical Discussions 22 March 27th, 2005 12:16 AM
Replacing pulley bearing Campbell Defender Technical Discussions 4 April 26th, 2004 08:42 AM
Need A/C tensioner pulley Campbell Wanted 0 April 24th, 2004 10:19 AM
