Temporary Steamy Exhaust - Defender Source
Old January 15th, 2008, 11:03 AM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
After searching I believe I might have a leaky head gasket. Anybody care to speculate????
- Non daily driver. 97 with 39k on it.
- Engine runs good with no overheating.
- Drove on Sunday after sitting for 2 weeks. Until warm LOTS of steamy exhaust, way more than normal. Does not smell excessively like coolant but really steamy on a colder (25 degrees) morning.
- Once warm the exhaust is normal.
- Oil doesn't show any brown or odd coloration.
- Just noticed about a week ago maybe a tablespoon of coolant on the garage floor. None dripping prior.
Thoughts?
Planning compression, coolant pressure and leakdown test. Anything else I should inspect?
Thanks in advance.
Boise, ID
Old January 15th, 2008, 11:38 AM
imola's Avatar
imola
I think that's normal. my 97 does the same thing when cold. unless you are loosing coolant you are ok.
Old January 15th, 2008, 12:01 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Seems normal as this happened to me also after a long stretch of non-use. The steam went away after about 10 minutes and hasn't returned.
Gary
Old January 15th, 2008, 04:10 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Sounds normal.
Watch your coolant reservoir just to be sure.
Old January 15th, 2008, 04:36 PM
Grover's Avatar
Grover
Question
Adam,
Did you look under the engine to see where it is leaking from? Front/rear of the block?
Old January 15th, 2008, 04:56 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Mine did that this morning leaving work.
Jimmy Buffett
Old January 15th, 2008, 05:52 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Someone correct me, but I believe this will occur until the cats heat up. Once everything reaches operating temps, the steam is gone. Most modern cars do this.
"Uhh...I think they all leak like that."
Old January 15th, 2008, 06:22 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Just the water vapor in the exhaust condensing on the cold pipes.
Old January 15th, 2008, 06:52 PM
GYM's Avatar
GYM
Gary
97 SW
Originally Posted by Ragland
...but I believe this will occur until the cats heat up......Most modern cars do this.
Happens on old, non-cat equipped cars too - condensation. On a cold morning, my '70 Road Runner steams like a locomotive until the engine warms up.......
Old January 15th, 2008, 07:52 PM
chrisconnie
Adam Hairston
97 LE #127/300
I am working on tracking the leak tonight.
Coolant level is normal.
Thanks for the feedback. I was hoping you'd suggest burnoff from non use.
Old January 15th, 2008, 11:13 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Does the horn still go "bee-beep"?
exhaust
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Wow, more exhaust woes. Hans Misc. Chit-Chat 14 May 27th, 2005 02:08 PM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
The sweet smell of exhaust!! bd90 Defender Technical Discussions 2 February 1st, 2004 07:46 AM
