Temperature indication - Defender Source
Old December 27th, 2012, 10:58 AM
atpick's Avatar
atpick
Andy
1990 110
I am trouble shooting a temp indication issue in my 110 and am looking for a little help. Trying to find the cause. When I turn the key, the temp gauge needle does move every so slightly, but will never move farther than that (remains just below "C"). The engine is obviously warming as at the end of the day I can feel a normal amount of heat from the engine when I check. I was curious as to you guys thoughts. Do you think it is the gauge, the temp sender, or the wiring? I changed out the contact on the temp sender which was a little corroded and still get the same result. Looking for ideas before I buy parts.
Cheers,
Andy
Old December 27th, 2012, 11:04 AM
Replace the sender.
Temperature Gague false reading trick? arbik Defender Technical Discussions 67 April 30th, 2017 09:45 PM
300 TDi coolant temperature range cdb Defender Technical Discussions 13 February 20th, 2008 05:44 PM
Temperature sender thread type/pitch? Neo Defender Technical Discussions 4 March 9th, 2006 02:40 PM
Transmission temperature gauge ripp2002 Defender Technical Discussions 27 February 12th, 2005 08:42 AM
Temperature Gauge doesn't work...?? norros Defender Technical Discussions 4 May 19th, 2004 04:11 PM
