Temperature Gauge / Question 94 D90 NAS - Defender Source
Old July 17th, 2016, 10:46 AM
limeport's Avatar
limeport
Chuck Burrows
94 D-90 #230
The temp gauge on my 1994 NAS Stock D90 goes up to 85% to H when idling on a hot day. Almost to hot , but not quite. Never overheats. Fan Clutch and thermostat have been replaced. Should I worry? There is a winch in front of radiator. Your thoughts are appreciated.
Old July 17th, 2016, 11:04 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
What does that guage even mean?
Has it always run at this spot?
I'd get a guage that has real numbers like 195*F and 230*F.
If it reads more towards the lower I wouldnt worry...
Use a laser temp and see what the tstat housing says.
Rent my
Old July 17th, 2016, 11:10 AM
bjf's Avatar
bjf
barry f
94 ST #395
How is your radiator?
Old July 17th, 2016, 11:15 AM
limeport's Avatar
limeport
Chuck Burrows
94 D-90 #230
Don't know how radiator is. Recently flushed when thermostat / fan clutch replaced. I don't have a laser temp gauge. Truck has only 32k on it and has sat some over the years. Was thinking about replacing radiator, surprised to see a new radiator is over $800.
Old July 17th, 2016, 11:17 AM
bjf's Avatar
bjf
barry f
94 ST #395
Check the fins. They rot. Mine did that. Replaced it and never saw the issue again.
Old July 17th, 2016, 11:29 AM
limeport's Avatar
limeport
Chuck Burrows
94 D-90 #230
Find look great and visual inspection of inside top of radiator looks good. Obviously can't see in core.
Old July 17th, 2016, 11:30 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Does it go back down when you get on the highway?
I had similar readings in my RRC and occurrence was very random. Turned out to be the voltage stabilizer. Not sure if a '94 D90 has one though.
Like Nomar said.... get a real gauge.
Old July 17th, 2016, 11:39 AM
limeport's Avatar
limeport
Chuck Burrows
94 D-90 #230
Goes back down to middle on highway.
Old July 17th, 2016, 11:41 AM
bjf's Avatar
bjf
barry f
94 ST #395
Original radiator?
Old July 17th, 2016, 11:50 AM
limeport's Avatar
limeport
Chuck Burrows
94 D-90 #230
Yup, it is
Old July 17th, 2016, 12:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yup, it is
You have ac?
Old July 17th, 2016, 12:06 PM
limeport's Avatar
limeport
Chuck Burrows
94 D-90 #230
Nope. No A/C.
Old July 17th, 2016, 12:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
Nope. No A/C.
Willing to bet anything it's your radiator.
Old July 17th, 2016, 12:29 PM
limeport's Avatar
limeport
Chuck Burrows
94 D-90 #230
So. Best place to get radiator? I assume I should get original LR and not aftermarket.
Old July 17th, 2016, 12:30 PM
bjf's Avatar
bjf
barry f
94 ST #395
Rovers North. They have a aftermarket one people swear by that is probably better quality than genuine.
Get one from them.
Old July 17th, 2016, 12:52 PM
Factory gauge without the actual readings has always scared me. Here's what to do first, in this order (as Nomar & others suggested):
1) IR gun on the motor itself, preferably at the stat housing and get a reading.
2) Replace the stock gauge with a VDO 310-105 & sender VDO 323-417.
Start with these easy/cheap solutions to determine what your temps actually are before throwing a radiator at anything. But since you did the stat & fan clutch at least you sort of ruled those out as culprits.
Old July 17th, 2016, 01:04 PM
Second the IR gun. You can get a cheap one for $5 from amazon.
There is no use trying to throw lots of money at trying to solve something that isn't a problem. As others have said, the gauge is almost totally meaningless - with no meaningful scale or gradations.
Old July 17th, 2016, 02:04 PM
Get a rover gauge and read the temp accurately from the coolant sensor which the ECU uses to know the engine temp.
Old July 17th, 2016, 02:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
I know it goes against conventional wisdom but it's a simple set up.
If the fan clutch and fan are working, and the head gasket is fine which it probably is, I bet it's the radiator. It's a 30,000 mile truck. I doubt he wants to modify gauges etc.
Bring it to you shop and have them check it. A 22 year old radiator is most likely done even if it looks fine.
Old July 17th, 2016, 03:13 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Infrared temp gun can be a priceless tool and can give you peace of mind or prevent you from really damaging something.
Reminder about the RN sale though. From the RN site:
Use Code 'BREXIT' to Save 15% Through Sunday Only
Out of curiosity , how long ago was the tsat and clutch replaced? Who did it? Have you checked coolant level? When you squeeze the upper radiator hose, do you hear fluid? Burping the air out of the coolant system can sometimes be a real pain.
d90, nas, 90
Wanted - 94/95 NAS Temperature Gauge or VDO Daniel1 Wanted 21 May 22nd, 2014 10:25 PM
Temperature gauge fogging up Caribsurf Defender Technical Discussions 4 July 10th, 2009 12:16 AM
FREE: Temperature Gauge madcowdungbeetle For Sale - Parts 8 January 29th, 2009 02:40 AM
Transmission temperature gauge ripp2002 Defender Technical Discussions 27 February 12th, 2005 08:42 AM
Temperature Gauge doesn't work...?? norros Defender Technical Discussions 4 May 19th, 2004 04:11 PM
