Temperature Gague false reading trick? - Page 4 - Defender Source
Old April 18th, 2007, 09:10 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
I'll check my numbers, what you need to duplicate is a stock 1994 NAS D90 temp system.
Email:
Old April 19th, 2007, 10:55 PM
dkjbama
Derek Johnson
'97 D90ST - Lil' Mule
What is the VDO part # for the temp sender to fit a '97 4.0? I've seen several different answers here and other places. Is it the same as the sender for the tdi? Part #323-095?
Thanks so much to anyone who can help.
DKJ
Lil' Mule - 1997 D90 ST Monza Red #1254
Old May 27th, 2009, 01:09 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up
For anyone looking for a recent update on this issue:
I've had my NAS 110 for about a week and have put this issue at the top of my fix-it-list.
I visited Mike's instructions here - http://www.eastcoastrover.com/signalconditioner.html to clarify the parts numbers. I noticed that ECR does not currently stock the parts for the fix. A quick phone call and ECR informed me that LR has created some confusion on the exact temp sender part number that mates with the AMR2631 '94 D90 temp guage and have been shipping the incorrect sender. ECR hopes to have the issue resolved soon.
Mike, when LR starts shipping you the correct parts again please let us know. Thanks!
Old September 26th, 2010, 07:34 PM
Ronanmd1
Jason
1997 D90 HS2.8
Temp sender?
Hey guys - I needed to replace the water temp gauge in my NAS 110 and checked out the link on the ECR site - http://www.eastcoastrover.com/signalconditioner.html. The conditioner in my truck has been removed. I installed the AMR2631 gauge, but I am a little confused about which sender to use. I ordered sender part number PRC7918, but noticed that this sender is red, not white. Also confused that some of the previous posts state to use the AMR2631 gauge and PRC7918 sender in order to reproduce the set up in the 1994 NAS 90 trucks, but your site states that the PRC7918 sender "is found in most NAS Defender 110 engines will cure the problem and show you accurate coolant temp. information. This change duplicates exactly the later Defender 90 temp. gauge, a system that was designed without any signal conditioning."
I'm a bit confused as to which temp sender to mate with the AMR2631 gauge to give an accurate reading.
Anyone have a 94 D90 parts manual and can tell me the LR part number for the sender unit in that truck?
Any suggestions guys?
Jason
Old September 26th, 2010, 08:16 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Originally Posted by Ronanmd1 View Post
I'm a bit confused as to which temp sender to mate with the AMR2631 gauge to give an accurate reading. Jason
use PRC2506 (1994 NAS D90 temp sender) with the ARM2631 (1994 NAS D90 gauge)
Click Here--->http://www.roverparts.com/Parts/PRC2506.cfm
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old September 26th, 2010, 08:48 PM
Ronanmd1
Jason
1997 D90 HS2.8
Thanks John - much appreciated...
Cheers,
Jason
Old April 30th, 2017, 09:13 PM
User Name
User
NAS D90 '95
Originally Posted by ECR View Post
The issue we found with Tdi set ups D90 is that you have to run the black temp sender. Most 300 tdi engines come through with a green sender and it is the wrong value for the NAS temp gauge.
Parts books (Euro ones) show the same part # gauge as an NAS 90 has mated to the balck sender. Once we installed that set up there have been no temp gauge issues. Run one in my own 90 and checked it in all conditions (Moab in the summer to Maine in the winter) with an infra-red tester and it was spot on.
OK, I just gutted an 1994-1995 NAS D90 temp gauge. nothing odd inside, no signal conditioner, just normal gauge guts, same as an NAS110 guage I just gutted.
300 Tdi in an 1993-1995 NAS Defender. use a AMR3321 black sending unit mated to a AMR2631 gauge. Exact same set up as a Euro D90/110. Checked this against factory Tdi cars we service (the illegal type).
NAS 110s come with a AMR2070 gauge
1994-1995 NAS D90s come with a AMR2631 gauge
To cure (with factory parts) an NAS 110 temp gauge issue use the PRC7918 "white" sender that most NAS 110 have in them and mate that to a AMR2631 gauge and remove the signal conditioner.
Did this a few years ago on some 110s and put them through the ringer including up to 120 degrees at idle in our paint bake booth and the gauge told the truth as per manual checks with an infra-red hand held.
Hope that helps.
Man is to hot here!!
My '95 NAS D90 has one.
Old April 30th, 2017, 09:45 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
From 2010, keeping it alive.
~ Semper Fidelis ~
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Transmission temperature gauge ripp2002 Defender Technical Discussions 27 February 12th, 2005 08:42 AM
Temperature Gauge doesn't work...?? norros Defender Technical Discussions 4 May 19th, 2004 04:11 PM
Trick tie rods skool Defender Technical Discussions 6 March 22nd, 2004 02:06 PM
