Temperature Gague false reading trick? - Page 3 - Defender Source
Old August 6th, 2006, 03:13 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Talking
Yes a stock 300 tdi will run hot like a 2.8 TGV. In my experience. The more difficult situation is an automatic transission equipted vehicle with A/C, on the highway at speeds above 65mph. Large tires add to the load and increase the max readings. Added fueling will add to the max readings as well.
I do not think a paint booth is a real test. Load similar to highway driving and higher ambient tempuratures would be more correct.
JP
An external oil cooler could be mounted anywhere that air can flow over it. For instance where the cooler for an auto transmission goes or in front of the radiator or condensor. Recoring a radiator can be done by your local shops. I recore to r-fin dimpled tube. I have done some oversized radiators now as well. But they are more difficult to install and fabricate. Ask anyone who has or is wainting for me to get one done for them
legend in my own mind
Old August 6th, 2006, 08:35 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Dude, you build Rads? No way.....
Old August 6th, 2006, 09:56 PM
artm
Arthur Maravelis
97 SW
I have not found the 110/300Tdi to be a hot runner. I recently recored the radiator. I did hope to replace it wiith a custom full width job but the need to find an intercooler that would fit (I have AC) in a short time did not allow for that. In two days of driving with outside temps in the high 80's, sustained 60mph with frequent bursts of 72mph, AC full on, max EGT at 1100, sustained runs of 4 hours - and coolant temps of 190. So far so good.
I have read that generally the Tdi is a cool runner. Considering that only one model radiator is offered, if it's good enough for the hottest parts of the world why shouldn't it work here?
So, with all this radiator talk, take a look here:
http://www.jagsthatrun.com/Pages/Par...-Radiator.html
The single core, wide fin, aluminum Corvette radiator described here may be very suitable for our V8/Tdi applications. Yes, single core and only 1-3/8" thick. So, forget your "4-core monsters".
I would certainly take a shot and have one made for my next radiator need - which may be quite soon for the 90.
More good cooling info from the same site:
http://www.jagsthatrun.com/V8-chapte...ing-System.pdf
Old August 7th, 2006, 06:41 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I have a single core full width aluminum rad on the way for the shop trucks 300tdi....along with a full width intercooler and separate oil cooler. It's a $2500 (just for the parts never mind the fitting) experiment.
The Tdi is still sitting on the floor so it's not overheating yet!(it does run quite nicely though)
Pendy......quit F)(*&^&^%$ around on the internet and get back to work for Pete's (or Daves) sake.
Matt Browne
Old August 7th, 2006, 08:42 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Rover offers a 3 core that most Tdi installers use and a HD 5 core radiator.
We have always installed the 5 core, perhaps this is why I haven't seen the issue?
On your installs are you using the 3 core??
As for temp tests in the paint booth, all I want to test is what the '97 gauge says as related to engine coolant temp. No, it isn't real world test but it will tell me if 220 appears as "normal" on the gauge. I don't have a dyno so that the best I can do.
Email:
Old August 7th, 2006, 11:35 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Yes 3 and 5 core. The LR 5 core is a good version. I try to use this version which works on most trucks. But some applications need more.
I see, the paint booth is just to verify high readings on the gauge, not a high tempurature running problem. Let us know.
JP
Old August 14th, 2006, 11:13 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Originally Posted by ECR
To cure (with factory parts) an NAS 110 temp gauge issue use the PRC7918 "white" sender that most NAS 110 have in them and mate that to a AMR2631 gauge and remove the signal conditioner.
This seems to work OK. With the stock 110 setup, the temp gauge never went past the middle of the gauge. When I got the 110, I promptly removed the signal conditioner (but didn't change the gauge) and when it was working hard, it would now approach the red end of the gauge (which made me worry a great deal), although an infra-red thermo check on the housing showed a temp of 200-210. I changed out the gauge over the weekend (thanks Rod!) and now when the infra-red reads 190, the needle is just South of the middle. It hasn't been hot enough lately to stress test it. I'm assuming I have the right sender (the connection end is white plastic) as I can't see a P/N on it anywhere.
Chance
Old August 14th, 2006, 05:33 PM
ECR's Avatar
ECR
The set up you have now is identical to that found in a 1994 D90 (a system designed by Rover without the signal conditioner) so it should give you much better information.
Email:
Old August 14th, 2006, 05:46 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Cool. Thanks for the good info!
Chance
Old August 17th, 2006, 04:17 PM
ECR's Avatar
ECR
I updated the page that started this thread to hopefully read better and give better info. for 110 owners about the signal conditioner. Let me know if it is any better:
http://www.eastcoastrover.com/110oillines.html
I'lll add pix next one I take out.
Mike, ECR
Email:
Old September 11th, 2006, 03:04 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok. 75 deg out side.... Steady at 70mph. THats where the temp is on my truck.. I think that is acurate and normal.... Using the VDO gauge and matching sender on the Tdi
Legend in My Own Mind.
Old September 11th, 2006, 03:22 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
What's the gauge on the left?
Old September 11th, 2006, 03:40 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
volt gauge Dave
Old September 11th, 2006, 06:38 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Randy-
gauges look great! I like how it is centered when warm, easy to tell if something is a miss... any advise on the sending unit? Looking at the universal VDO sender kit... does it just skrew right in?
Old September 11th, 2006, 06:55 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
You just need the gauge and the sender #323-095 and you are good to go. It does creep up a little if you really beat on it or its really hot outside. Usually between the next two hash marks is the highest it ever went...
www.egauges.com/vdo_grou.asp?Series=Vision
Old September 11th, 2006, 08:23 PM
artm
Arthur Maravelis
97 SW
So, where's your EGT gauge and what readings are you getting?
Old September 11th, 2006, 08:50 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Don't have one yet... Have to look for a place to put it.. Does anyone make a pod that goes on the A pillar for gauges?
Old September 11th, 2006, 09:09 PM
artm
Arthur Maravelis
97 SW
I would put it next to the speedo and move the fuel gauge out of there. Certainly EGT is more critical than fuel so you want it staring you in the face.
Old September 11th, 2006, 09:20 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You ever primed a Tdi? It's no picnic.
I say pull the volts (although I like view into your system).
No need for a tach either. I've been thinking about getting rid of mine.
Old April 16th, 2007, 07:56 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
White? Sender
Per Mike at ECR...
"To cure (with factory parts) an NAS 110 temp gauge issue use the PRC7918 "white" sender that most NAS 110 have in them and mate that to a AMR2631 gauge and remove the signal conditioner.
Did this a few years ago on some 110s and put them through the ringer including up to 120 degrees at idle in our paint bake booth and the gauge told the truth as per manual checks with an infra-red hand held."
I ordered the sender part #PRC7918, and it is not white. The end that sticks out, and you plug the wire into, is red. What would be "white" in the sender?
red?
http://www.roverparts.com/Parts/PRC7918.cfm
white?
http://www.roverparts.com/Parts/PRC2506.cfm
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Transmission temperature gauge ripp2002 Defender Technical Discussions 27 February 12th, 2005 08:42 AM
Temperature Gauge doesn't work...?? norros Defender Technical Discussions 4 May 19th, 2004 04:11 PM
Trick tie rods skool Defender Technical Discussions 6 March 22nd, 2004 02:06 PM
