Temp tires - Defender Source
Old December 13th, 2013, 06:45 AM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Temp tires
Tying to fit D90 into my cargo trailer and with tires near flat just a couple inches too high. Was thinking of hitting salvage yard for a set of those small temp tires to lower it that much more.
Don't suppose anyone might know of a vehicle that has such a match before I go through measuring each one? (Ex. Ford focus or something)
Old December 13th, 2013, 08:15 AM
if you are running stock 265/75's a set of disco 1 wheels with the 245/70's will drop you 2 inches. If you are that tight I'd be worried about what happens as the suspension works while in tow.
http://www.tacomaworld.com/forum/tir...0r16-265-75r16
Old December 13th, 2013, 09:06 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
2 in diameter but about 1 in sidewall height, right
Old December 13th, 2013, 09:26 AM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
I was thinking those mini spare tires the manufacturers put in late 90's to mid 2000's. Temp use only, don't exceed 55 etc usually found in trunk. It's the lug spacing need to match.
Just need the clearance to get through the door, once inside additional 6-8" of room.
I'm just being lazy and thought someone else may have gotten bolt pattern spacing and been through similar situation.
Either way I'll post when I find for future reference.
Old December 13th, 2013, 10:41 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Can you compress the suspension enough, like with HD ratchet straps, enough to get it in? Also that would potentially keep it from flexing and hitting the roof in transit. Might want to use two at each corner for redundancy.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 13th, 2013, 12:31 PM
Pull the rear springs and put it in on the bump stops.
Old December 13th, 2013, 12:56 PM
spring compressors....
Old December 19th, 2013, 04:05 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Well like Jeff said nothing matches at wrecking yard, shucks, and I'm a little spooked compressing springs for long hauls. This may be the fodder needed for a new trailer.
Old December 19th, 2013, 04:15 PM
With all due respect, your whole plan does not make sense. If you need to go two inches lower with the tires flat on 16" rims, you would need 12" rims. Obviously....that is not possible.
- Throw a huge load into it.
- Remove the springs.
- If you have a lift, then putting in stock or very light springs.
- Take the roof off.
Old December 19th, 2013, 04:19 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
or buy a set of crap rims and drive it into the container without tires...
Old December 19th, 2013, 05:22 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
second
Old December 19th, 2013, 05:44 PM
Ask the CBP for help. They are good at compacting Defenders....
Tires: an odessy souza Misc. Chit-Chat 37 December 14th, 2009 05:57 AM
Tires, Tires, Tires Joe P Misc. Chit-Chat 28 August 9th, 2005 09:58 PM
4 BF Goodrich Mud Tires Jeremy Keith For Sale - Parts 5 March 3rd, 2005 07:09 PM
BFG AT Ko tires for sale Seriesman For Sale - Parts 6 August 18th, 2004 11:09 PM
FS: Used Goodyear G-90 Tires mlepisto For Sale - Parts 3 March 25th, 2004 02:30 PM
