Temp Sensor Values - I'm Not Sure if its Overheating! - Defender Source
Old April 5th, 2012, 11:19 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Long story short, I replaced the gauge with the later style (I believe, bought it second hand and it's installed now, so I can't see it at the moment to get numbers off it, but that is the next check. I removed the signal conditioner and now the vehicle keeps overheating. I am not sure it really is, but the thermostat isn't opening and the gauge goes to the red shortly after starting. I played with a laser thermometer a bit and it leads me to believe it isn't running hot, but I don't want to take a chance either. I replaced the sensor yesterday, thinking I may have had the wrong one, but I'm still not sure I have the right one. ECR says it is white, but I ordered the part number they suggested and it came with a red insulator, not white.
Needless to say, same result. I have bypassed the leaking heater core for the time being, and just want to be able to drive it a few miles to the shop so I can get to work on the heater core and some other things.
All in all, I have a new Sensor that I'm not sure is correct, a New to me Gauge that I'm not entirely sure, but 99% sure is correct and I'm planning to replace the T-Stat tomorrow. In the mean time, does anyone know the correct values I should be getting at the gauge? I would like to test and see if I can narrow this down some more rather than replacing everything one at a time. Plus, I want to know for sure if it is running hot or I am just getting false readings.
Old April 5th, 2012, 11:47 AM
the ground to the gauge can have a huge effect on the signal, and if the sender is not matched to the gauge, then same effect. the sender basically sends a resisted ground signal to the gauge, and the gauge compares that to the gauge earth to the temp. the sender will have a resistance range of x-y representing it's full range, and same with gauge.
do you have an actual probe thermometer? if so, you can drop that into your t-stat housing to take a reading, and compare actual temp to indicated temp on your dash.
I got a $10 IR temp gauge at harbor freight when I was going through the same thing on my diesel, and it ended up being the ground I was using to my vdo gauge. made about a 20-30 deg difference in indicated temp alone.
Old April 5th, 2012, 01:11 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Good to know, I'll check that as well.
overheating, sensor
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
» Defender Registry
#304
TRS
Domino
Tripod
Add your Defender
