Temp sending unit 3.9 liter - Defender Source
Old February 12th, 2014, 08:51 PM
Chrisgrace
Chris Grace
1995 Defender 90
Recently my temp gauge on my 95 D90 became inoperable...no reading. I ordered a new sending unit,part # PRC2506 and installed it. Started the engine and let it run up. The gauge slowly began reading and climbed steadily to the center of the gauge...but then kept going,right to the edge of the red. The engine was not hot. The gauge wasn't pegged,just stayed at the edge of the red.
Thought the unit might be faulty,checked that it was the right number and obtained a new unit.same story . Climbs right to the red and stabilizes...the engine is not over heating.
It seems like the unit I am installing is not calibrated for my gauge.
Any thoughts or suggestions?
Old February 13th, 2014, 07:24 AM
Are you sure your gauge is original?
A mismatch between gauge and sender type would cause incorrect readings.
Also try running a wire direct from the sender to the back of the gauge ... In case the original wire is at fault.
Then check the condition of all the wires on the back of the gauge.
Old February 13th, 2014, 08:56 AM
Chrisgrace
Chris Grace
1995 Defender 90
Thanks. Gauge is original. I have owned the truck since new. I think you are right ,there is a mismatch between sender and gauge,just don't know why. I will check the wiring but that seems unlikely since the gauge is not going to the peg,it works smoothly,progressively and moves off the peg as the engine warms.
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
4.0 temp gauge sending unit size 97-D90-736 Defender Technical Discussions 4 January 6th, 2012 12:52 PM
Water temp sending unit 4.0 97-D90-736 Defender Technical Discussions 5 March 24th, 2011 03:42 PM
94 3.9 liter w/ac where do i find codes max Defender Technical Discussions 6 January 16th, 2011 05:49 PM
Temp sending unit 3.9L vs 300TDI - different range? jaherring Defender Technical Discussions 8 October 4th, 2010 08:22 PM
