temp sender size - Defender Source
Old June 1st, 2006, 07:08 PM
mattdh's Avatar
mattdh
Matt Hurst
temp sender size
so what is the temp sender size? i screwed it into a 5/8-16 hole i also screwed in a 16-1.5 into the same hole? are these that close?i can not find an adaptor that is 5/8-16.some ones got to know this-as many threads as there are on the temp gauge swap
Old June 1st, 2006, 07:55 PM
btate
Bryan Tate
d90
I just did this last week.
I went thru 3 senders.
I settled with the m16 x 1.5 (a few threads stick out as it is longer than stock)
No leaks, I called VDO tech they said its ok as long as it isn't leaking
Old June 1st, 2006, 08:00 PM
mattdh's Avatar
mattdh
Matt Hurst
was this an adaptor or is the sender 16x1.5?
Old June 1st, 2006, 08:24 PM
btate
Bryan Tate
d90
the sender is 16x 1.5 for the VDO gauge swap...Part No: 323-417 is what I used
Like I said, it worked but I felt a little uneasy that it didn't thread in all the way
Old June 2nd, 2006, 01:42 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
When I do a VDO swap I open the original temp sender hole to 3/8NPT. The threads that are there are close but not tapered. I just run a 3/8 NPT tap into the original threaded hole. It can easily be done with the manifold on the truck.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Temp Sender Location DJ Menasco Defender Technical Discussions 10 August 28th, 2006 01:24 AM
Temp Sender Thread Size for NAS110 surf110 Defender Technical Discussions 2 August 18th, 2006 09:36 PM
95 D90 temp sender range naeirie Defender Technical Discussions 2 April 27th, 2005 12:16 PM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
