Temp sender? is whacky - Defender Source
Old May 23rd, 2012, 11:27 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
First thing in the morning I turn the key to the first position and the temp gauge goes up to the bottom of the red mark. Then I start the truck and as I'm driving down the road the gauge eventually creeps up to full panic mode. The cooling system has been working fine so I'm not all that concerned about the engine's health, ie bottom hose is nice and warn to the touch and not hot. This just happened over night so I'm thinking it's the sender.
The last time I ignored a bad sender I actually was having coolant issues and ended up in a bad place so I am a bit weary. Needless to say, the sender and radiator have been replaced and the head has been rebuilt a little over a year ago.
Is this an issue that others have had pop up overnight? Hopefully it's just a new temp sender.
Jeff
Old May 24th, 2012, 12:25 AM
cdb
Clark Bowen
Temp sensors are about $9 from www.britishpacifc.com or $32 from LR. Easy to replace too.
2011 RR HSE -
2001 GMC 2500 4wd
Old May 24th, 2012, 01:18 AM
michael67's Avatar
michael67
Michael White
110 Tdi
I was having the same issue. Make sure you don't have a ground problem:
- Check the condition of the ground wire from the battery, including where it attaches to the body/frame
- See if connecting a parallel wire from the battery directly to the engine to ensure a good reference ground helps
- Make sure your gauge has a good ground by connecting a parallel ground to the battery
I'm assuming you're running the stock gauge with stock connectors.
Old May 24th, 2012, 04:42 AM
Out of interest what does it read if you remove the wire from the sensor and ground it on the block?
Old May 24th, 2012, 11:36 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
When I do this the gauge goes all the way to the top.
Old May 24th, 2012, 12:37 PM
buy a VDO guage and sender
eguages.com
Old May 24th, 2012, 12:53 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I probably should do that. The "red" is actually pretty much white at this point.
Does anybody know the part number for the sender? I bought one from LR Series last time but it was the wrong one. This is for a 2.25 five bearing diesel.
Edit: just looked at egauge site and see that they have the senders with the gauges and adapters. Will investigate that option further.
Old May 24th, 2012, 01:45 PM
eguages.com
Do it!! Cheaper than a stock gauge and sender, they actually work, they look much better and can be read at night...
Old May 24th, 2012, 07:11 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
I'm having similar issue with mine. Figured sensor, was sent wrong one from RN, sent me another claiming to be the right one and was still wacky..... Basically gauge goes to mid within a minute then quickly redlines..... obviously engine not heating up that quick but its a bit unnerving.... So as Jason recommended & scored..... swapped vdo..... have not chance to really test yet... hopefully tomorrow.....
Still curious whether I was sent wrong sensor again, bad ground though I doubt it, have redone most or gauge is bad.... mystery.....
Old June 27th, 2012, 07:53 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Got my VDO today. Gonna try to get it in tomorrow. I am certainly no electrical wiz but what in the hell is a person supposed to do to connect a wire to the sender? The top of that thing looks like nothing I have ever tried to wire up before.
Old June 27th, 2012, 08:14 PM
The same connector as the old one ... Or maybe a slightly different size should fir right on!
Old June 27th, 2012, 08:22 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Well there is a spade type connector on the one in there right now so I'm not sure how that will work.
Old June 27th, 2012, 08:24 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
If you're old one is a stud type connector then you need to change it to a spade type. The spade goes on from the side. See pic.
If your stock wire is really skinny then you're better off running a new wire back to the gauge from the sender to avoid false reading issues.
Name:	New Sender.jpg
Old June 27th, 2012, 08:25 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Attachment 53574
Cut a slot in the side of the plastic cover and slide it on the new one from the side.
Better to run a new wire though really.
Old June 27th, 2012, 08:50 PM
michael67's Avatar
michael67
Michael White
110 Tdi
A standard female spade connector from Home Depot worked for me. Just cut the insulation on the open side of the spade connector and slide it on.
Old June 27th, 2012, 08:59 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok that makes total sense now.
Thanks so much!
Jeff
ac
Temp sender question cgalpin Defender Technical Discussions 8 February 18th, 2011 08:10 AM
Temp Sender Location DJ Menasco Defender Technical Discussions 10 August 28th, 2006 01:24 AM
95 D90 temp sender range naeirie Defender Technical Discussions 2 April 27th, 2005 12:16 PM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
