Temp issue - Defender Source
Old July 20th, 2015, 12:36 PM
Ai91
Anthony
97 defender 90
Temp issue
My 90 has been having issues with the getting hot sitting in traffic or when I run the ac. I just replaced the fan clutch and recored the radiator and added a 4th core. A few times sitting in traffic the needle went almost in the red without the ac on. Even at highway speed with the ac on the car will still go to about 3/4 the way to the red on the gauge. Any idea what this could be?
Old July 20th, 2015, 12:38 PM
Water pump.
Old July 20th, 2015, 12:43 PM
101stAirborne's Avatar
101stAirborne
Battle Ewing
1997 D90 LE 255/300
I'm having the same issue
Old July 20th, 2015, 12:51 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by javelinadave View Post
Water pump.
x2 on the water pump. I suggested this in another post but others seemed disagree. My issue was only when climbing this one particular mtn pass. But as soon as I replaced it the problem never repeated itself. Guess I was lucky.
I think others had had issue with cores being too big and not effective. You might search for this issue here to see if that sounds like what you've got going.
rovertrader's Avatar
rovertrader
Dale
Some say the 4 core hurts as the last row doesn't cool sufficiently. I went with a 3.5 rad, new viscous, and external oil cooler, and have gotten back to center. And I have a fairly spicy 4.6- still will move to 3/4 under hard use, but cools right down, and no issues when stopped/sitting. Working for me.
Old July 20th, 2015, 12:59 PM
Ai91
Anthony
97 defender 90
Thanks guys. Do you think I should stick to an oem water pump?
Old July 20th, 2015, 01:00 PM
gwmckee
George
1994 NAS D90 #1919
Have you checked your thermostat? It might be stuck. Since you just did the rad work, I'm assuming your coolant level is good.
Old July 20th, 2015, 01:01 PM
As opposed to a Shitpart (Britpart), ABSOLUTELY!
Old July 20th, 2015, 01:05 PM
Ai91
Anthony
97 defender 90
Thermostat is good. Coolant level is good as well.
------ Follow up post added July 20th, 2015 11:05 AM ------
Haha ok thanks..
Old July 20th, 2015, 01:42 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Sorry nothing to add to help this case but I am interested to hear about water pumps.
It seems to be a very simple design with a pulley, a bearing and an impeller that moved the water.
My only experience with failed water pumps is when the bearing dies (and the "pump" makes noise/coolant leaks out).
How would a water pump lose its capabilities over time? I would not think coolant is abrasive enough to eat up the impeller.
What's the difference between OEM and other lesser part in term of the impeller (yes bearing could be lesser and die prematurely).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 20th, 2015, 02:23 PM
1of40's Avatar
1of40
1of40
I would consider it. A friend of mine owns a small Rover shop. His little shop does lots of little stuff like this and brakes and probably 8-10 engine swaps a year. In his personal experience non-genuine parts fail more often.
Old July 20th, 2015, 02:29 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You've got a '97 which should be OBDII. For the love of God just get a Bluetooth plugin and phone app so you can see the real temperature. $30 should get you both and you don't have to wonder just how hot your truck really is.
Old July 20th, 2015, 03:05 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Second what Brett says. Have the GoPoint Bluetooth dongle; extremely precise.
Old July 20th, 2015, 03:06 PM
1of40's Avatar
1of40
1of40
What's Blue Tooth?
Old July 20th, 2015, 11:55 PM
Departing90
Sasha
95 D90
Make sure you wanter pump and thermostat work as should. Check coolant flow. If you still have coolant flow issues then you have a clogged heater core. Disconnect both heater core hoses and run a garden hose through either one and notice the flow. If you see crud come out keep running water untill it clears. If you cant unclog it find a shop to rod it out or replace it.
20 minutes after it reaches operating temp in stop and go traffic pull over and look at tye upper radiator hose. If its swollen and hard its a sure sign you have a cracked block or blown head gasket in one of the heads!
Old July 21st, 2015, 10:01 AM
MonLand
Loic Fabro
Extremely precise assuming the sensor is providing the right information.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 21st, 2015, 10:17 AM
Ai91
Anthony
97 defender 90
I'll look into the Bluetooth thing.. This morning I had the issue again. Didn't have time to jump out and check the top rad hose. Truck gets hot and you can hear the engine get louder. also I noticed I'm getting a ticking noise that sounds like it's coming from the passenger side footwell. Even when I shut the ac the temp didn't start to drop after.
Old July 21st, 2015, 12:30 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Water Wetter might help until you make necessary repairs
Old July 21st, 2015, 12:41 PM
Ai91
Anthony
97 defender 90
I'm using water wetter now mixed in with coolant and water.
Old July 21st, 2015, 12:42 PM
Departing90
Sasha
95 D90
The misconception that water wetter is better than coolant comes from racers using it in bikes and cars on several tracks. They use it because coolant containing propylene glycol is very slippery, is akin to black ice on a track and is banned at most tracks! You may see, and its a big maybe to get a 5-10degree reduction in temps in extreme racing conditions. Most people experience no dicference in temps with water watter and some have even reported lower temps with just plain H2O compared to water wetter. Your milage may vary.
200TDi Temp Gauge & Sender issue Jonesy Smaller Projects 9 September 29th, 2014 01:11 PM
VDO Temp Gauge issue sloanfiske Defender Technical Discussions 24 August 6th, 2014 11:24 PM
Heater temp control issue... silverlight Defender Technical Discussions 15 January 3rd, 2013 12:03 AM
temp sender issue melittle Defender Technical Discussions 6 November 5th, 2012 01:20 PM
200 tdi Temp Sender Issue Wolf Fabrication Defender Technical Discussions 13 January 14th, 2010 12:35 PM
