Temp Guage Position - Defender Source
Old October 15th, 2005, 12:38 PM
willtillery
WILL TILLERY
TO MANY ROVERS
Temp Guage Position
OK My disco falls right below the mid mark. My d90 is top dead center. Trying to get an idea of where most folks temp guages fall. (when at operating temp)
Old October 15th, 2005, 05:11 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
I wouldn't trust that stock gauge, mine was all over the place. I followed the advice of another member here and replaced the electronic temp sender and gauge with a mechanical gauge which gives an actual temp reading. Very easy and inexpensive. I'm usually between 185 - 195. The hottest I've gotten is 210 a couple of times.
Temp guage problem TDI Guy Defender Technical Discussions 24 June 28th, 2013 10:42 PM
Wont run at temp Neo Defender Technical Discussions 12 February 24th, 2006 06:54 PM
aftermarket temp guage options draaronr Defender Technical Discussions 7 January 4th, 2005 02:33 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
