Temp gauge wiring - Defender Source
Old October 6th, 2011, 03:55 PM
atpick's Avatar
atpick
Andy
1990 110
Temp gauge wiring
My temperature gauge is not working. Wiring is not my forte to say the least, so with that said...
1) Any ideas on where to start trouble shooting
2) Where does the gauge wiring connect to sense the tempature? I'm guessing somewhere in a coolant line perhaps? (Again...clueless)
The engine is a stock 1984 3.5L V-8. Any help would be great!
Cheers,
Andy
Old October 7th, 2011, 08:51 PM
michael67's Avatar
michael67
Michael White
110 Tdi
Pull down the service manual(s) for your truck (Google something like "defender workshop manual"). They are free and you should have it if you're going to own something that old.
I'm assuming your gauge is not working, and that you've confirmed your engine is actually heating up (i.e. thermostat is OK).
Locate the temperature sending unit. Open the dash so you can get to the temperature gauge wiring. You should be able to figure out what's wrong in just a few steps:
1) Pull the wire off the sending unit and pull the corresponding wire off the gauge. Measure the resistance. If the circuit is open, you have a bad wire.
2) With the sending unit wire still disconnected, run a wire from the gauge where the sending unit wire was attached to ground. Very briefly turn on the ignition and turn it off. If the gauge moved (likely pegged), then your gauge is probably OK.
3) Put everything back together, cleaning all connections and making sure all connections are good. See if your gauge works now. If so, probably a loose connector - replace/fix the connectors on the end of the wire.
4) If the above doesn't isolate problem, replace the sending unit.
wiring
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
