Temp gauge removal - Defender Source
Old March 23rd, 2013, 01:02 PM
atpick's Avatar
atpick
Andy
1990 110
Temp gauge removal
Anybody know how to get the gauge out of the cluster?
ID:	68769   Click image for larger version
Old March 23rd, 2013, 01:35 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
That little bracket has a circular nut on it that you can spin off by hand. When that is off and the wires are off you can pull it through. If you unhook the speedo cable you'll get some more room to play with. Squeeze the white connector and pull back from the speedo to release. Sometimes it needs a strong wiggle. At least that's what it's like on a 94.
Old March 23rd, 2013, 01:50 PM
atpick's Avatar
atpick
Andy
1990 110
Ok the nut if off but still seems in there pretty good, does it slide forward or back?
Old March 23rd, 2013, 02:06 PM
Broncoduecer
peter
D90
I think after years they get gunk behind the face ring and it kind of glues them in there. I would think now you should be able to rotate it and then push it out. Maybe some windex in the groove between the dash and the ring might loosen it?
Old March 23rd, 2013, 02:56 PM
atpick's Avatar
atpick
Andy
1990 110
Ok, thanks for the help for it switched out, now just trying to find where the speedo cable hoks back up to....
Old March 23rd, 2013, 03:25 PM
atpick's Avatar
atpick
Andy
1990 110
Now the speedo won't work, think I unhooked something, does have something to do torn this little weird metal thing...
ID:	68796   Click image for larger version
Old March 23rd, 2013, 04:48 PM
The connector in the middle of the speedo is probably loose. Be careful though they are pretty fragile.
Old March 23rd, 2013, 04:55 PM
atpick's Avatar
atpick
Andy
1990 110
Yeah, I checked it and it appears the cable broke somewhere down line from the gauge as I was able to pull it out from the engine bay. Oh well, something to fix when I get back from the suck. I like the new gauge though. Interesting tidbit, it runs about 10 to 15 degrees cooler on propane.,.
ID:	68819   Click image for larger version
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
