Temp gauge reading issue - Defender Source
Old July 24th, 2016, 05:11 PM
trader2318
scott
1997 D90 NAS
Truck is a 1987 with a 2.5 turbo.
Looking for advice...
I am looking to troubleshoot the reading that I am getting from my temperature gauge. With the engine cold, I turn the key to get the reading shown below. After running for a bit around town, it will move up to the gap, the black area before the orange. The gauge is tied the the temp. sensor as when I unplug, the gauge drops to no reading.
Any thoughts?
ID:	154426   Click image for larger version
Old July 24th, 2016, 08:43 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Scott,
Read these, then report back.
http://www.defendersource.com/forum/...ing-72105.html
http://www.defendersource.com/forum/...uge-71942.html
Also try this link and search for "overheating": https://cse.google.com/cse/publicurl...95:8zpbxe3x-t4
-Neil
Old July 24th, 2016, 09:20 PM
Tarheeld
Bill
1985 110
could also be the radiator; a rerod could be in order?
Old July 24th, 2016, 09:58 PM
trader2318
scott
1997 D90 NAS
Thank you both for the your thoughts. Steinhnj, I read the links you posted and thanks for that custom search page...very cool.
I am going to start with the sensor. To add clarity to my initial post, I am getting a high/hot reading with an engine that has been started today, with the key in the #2 position, not running. I have no other evidence that the truck is running too hot, just a weird acting gauge. If its not the sensor, I am thinking electrical issue (but no other problems) or incompatibility between sensor and gauge.
I will invest in an IR gun and give the water pump pulley a look as well.
Much thanks.
OEM fuel gauge, water temp gauge and tach defender1844 For Sale - Parts 4 June 27th, 2016 12:45 AM
200TDi Temp Gauge & Sender issue Jonesy Smaller Projects 9 September 29th, 2014 12:11 PM
VDO Temp Gauge issue sloanfiske Defender Technical Discussions 24 August 6th, 2014 10:24 PM
Reading the stock temp gauge? dsh12 Defender Technical Discussions 3 October 4th, 2012 03:56 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 02:50 PM
