temp gauge question - Defender Source
Old September 4th, 2013, 02:12 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
temp gauge question
Is there an easy way to test the temp gauge? It has not worked since I got the truck and that make me nervous. I have replaced the sender unit and still nothing. I at the wiring diagram and have an idea but I dont want to fry anything.
thanks
Old September 4th, 2013, 02:17 PM
Test the resistance at the sensor and at the wire at the gauge while it is unplugged from the gauge but plugged into the sensor. If it isn't close to the same it's the wiring. If it is, it's the gauge.
Also double check that the gauge is well grounded. No ground = no work.
Old September 4th, 2013, 03:17 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Thanks, I will check it out
Temp Gauge question Etrier Defender Technical Discussions 13 May 26th, 2006 06:18 PM
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
