Temp gauge problems - Defender Source
Old March 9th, 2009, 10:02 PM
bennett's Avatar
bennett
Bennett
'97 Defender 90 Soft Top #1140
Temp gauge problems
So my temp gauge only works intermittently. I had it checked out and had a "failure to duplicate". No wiring issues. It will go from a normal temp reading to cold all of the sudden, and my check engine light comes on showing that my temp gauge is out of range. Has anyone ever had this problem? Im not overheating, so im not too worried about it for now
Old March 9th, 2009, 10:19 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I would check all your connections. Pull them apart, clean them up and put them back together. I would bet you will find one of them is loose.
Old March 9th, 2009, 10:27 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Check your ground wires. There are a lot of vehicle electrical problems that have poor grounds, corroded grounds, etc. as their root cause. I would find the various grounding points clean then off with emory cloth and then use dielectric paste when reattaching.
Old March 9th, 2009, 10:28 PM
johnpiero
John Brancato
none
I had a similar issue. My temp gauge would quickly dial over to the overheating side when I pressed on my horn. NO JOKE. Apparantly I had a short on my blinker and it was sucking too many amps. The low amps caused my gauge increase. So I guess, you can check your grounds for a fault.
It still seems odd, but I'm very serious. Good Luck!
Old March 10th, 2009, 01:26 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I was shocked how inacurate the stock guage is. Mine wasn't even close. I would spend a little bit of money and replace the sensor and the guage. You can clean up wiring when you do it. It's a mess in there.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 10th, 2009, 11:28 AM
61rover's Avatar
61rover
John Crouse
Temp Guage
x2 on replacing. Go the VDO route. You'll be glad.
Old March 15th, 2009, 02:50 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Agreed. I have a 100% manual thermometer-bulb-type gauge that reads out of the radiator just below the top hose. 100% accurate all the time even when the truck is turned off.
Old March 15th, 2009, 10:16 PM
bennett's Avatar
bennett
Bennett
thanks for the suggestions all.
problems
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
