Temp gauge issue - Defender Source
Old May 31st, 2015, 10:40 PM
bababoris
Boris Kogan
1993/Defender 110
Temp gauge issue
I have a Canadian number 24 Defender 110. It is all original. I hardly drive it. It has about 121k km on it. Here is my issue.
When I start and let the truck warm up the temp gage jumps into the red zone after running for 2-3 min. I check coolant* before I drive and it's always full. I am trying to figure out if I need to flush my radiator to insure proper water circulation or I have a bad temp gage, or perhaps something else is cause the team to spike. Thanks in advance
Old May 31st, 2015, 10:45 PM
Boris,
You have an electrical issue with your sender, gauge, wiring or a combo of them. I would start with double checking the grounding of the gauge and go from there.
Old May 31st, 2015, 10:59 PM
bababoris
Boris Kogan
1993/Defender 110
Thanks. Is that something a mechanically challenged person could figure out how to troubleshoot?
Old May 31st, 2015, 11:07 PM
Find the temp sender located on the thermostat housing and see that the wire is making good contact. Pull the connector off and look for corrosion. Beyond that you may want to hit up and auto electrical shop. They can diagnose it faster than I could type what to try next.
Old May 31st, 2015, 11:36 PM
bababoris
Boris Kogan
1993/Defender 110
Got it. Thank you sir
Old August 20th, 2015, 06:36 PM
bababoris
Boris Kogan
1993/Defender 110
Looks like both the gage and the sending unit were bad. Getting both replaced.
Old August 20th, 2015, 06:49 PM
Ditch the LR crap and buy VDO gauges and senders.
Old August 20th, 2015, 06:54 PM
bababoris
Boris Kogan
1993/Defender 110
They guy at the shop is sourcing a gage to keep the original look
Old August 21st, 2015, 11:29 AM
barjout
Marc Bourget
1996/Tdi DEFENDER 110
The VDO gauge wont change the original look and will get you a reading with numbers which is more accurate. When I replaced both the gauge and sender I replaced the signal wire at the same time with a bigger gauge. Never had an issue since.
Old September 4th, 2015, 03:19 PM
bababoris
Boris Kogan
1993/Defender 110
So I got my truck back. Guys at Huntington service in So Pasadena were great. They replaced the gage and sending unit but could not find a gage that looked close enough to the original. Attaching a pic of the new gage. They said something about the older gages not being able to work with sending units wherr they had to account for higher Temps that defender run. Or something like it. I kept the original gage. Any chance the original gage can be repaired? And should I call around defender parts stores to see if I can find an original working gage and sending unit?
Old September 4th, 2015, 03:27 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
They said the VDO Stuff is not available any more?
Check the FAQ article..
D-90 FAQ - Interior & Comfort: Instrumentation
From FAQ Article:
VDO Vision Temperature Gauge: 250 degrees F, 310 105
VDO Sender, 250F, 5/8-18UNF, 323 422
(Looks like eGauges have both of these in stock)
As well as this thread for more VDO info..
http://www.defendersource.com/forum/...ist-37620.html
~Scott T.
'95 D-90 ST - AA Yellow
Old September 4th, 2015, 03:41 PM
Attachment 128792
Wow ... that's ugly.
Hopefully they didn't charge you any money ... the devaluation of your vehicle is going to hurt enough.
VDO gauges are easy and cheap to source, they install on the existing wiring, have a replacement sender and it takes about 30 mins to change by a half competent DIYer.
Old September 4th, 2015, 03:44 PM
Did it come pre-scratched from Walmart?
Old September 4th, 2015, 03:45 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
And the VDO gauge will match your other VDO gauge.
Old September 4th, 2015, 03:50 PM
VDO Vision Black Engine Temperature Gauges (Electrical) - eGauges.com
$45 including sender...
Old September 4th, 2015, 03:54 PM
bababoris
Boris Kogan
1993/Defender 110
I don't want to bash the guys there. I think they really tried. I just sent them the link to the VDO guage that looks like the original. Its also half the cost of the one they installed. They said they will look into it. Thank you all for your feedback. I am a crappy DYIer so will let these guys fix it. Will keep you posted. Thanks again
Old September 4th, 2015, 03:57 PM
I've just realized this is a 110 .. sorry to mock your misfortune but the 110 has a device on the back to mask the temp readings. Early buyers complained that the gauge moved and LR added a circuit to prevent the gauge reading properly.
NAS Defender 110 temp. gauge
This needs to be removed if it hasn't already. I'd be hugely surprised if your truck overheated after 2-3mins running ... more likely an electrical fault, especially as you rarely use it, likely some minor corrosion,
You really need to take this to someone knowledgeable as the work done is clearly not in keeping with the vehicle and their explanation doesn't stand up to scrutiny.
Old September 4th, 2015, 04:24 PM
bababoris
Boris Kogan
1993/Defender 110
Just spoke to Rovers north in Vermont. They can order an original gauge for $319. Ouch...
They also have a sender that works with it for $9. I am leaning towards getting this original guage ...
Old September 4th, 2015, 04:26 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
That is a must, and oil cooler lines...I was lucky last year when my line blew and sprayed all over the exhaust manifold. I knew exactly what was happening and shut it down right away as soon as I saw the clouds coming out the back.
NAS Defender oil line upgrade
Old September 4th, 2015, 04:46 PM
The VDO gauge is used by many people here. Its accurate, reliable and is similar looking to other gauges.
200TDi Temp Gauge & Sender issue Jonesy Smaller Projects 9 September 29th, 2014 01:11 PM
VDO Temp Gauge issue sloanfiske Defender Technical Discussions 24 August 6th, 2014 11:24 PM
Heater temp control issue... silverlight Defender Technical Discussions 15 January 3rd, 2013 12:03 AM
temp sender issue melittle Defender Technical Discussions 6 November 5th, 2012 01:20 PM
200 tdi Temp Sender Issue Wolf Fabrication Defender Technical Discussions 13 January 14th, 2010 12:35 PM
