Temp gauge issue - Page 2 - Defender Source
Old September 4th, 2015, 07:55 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
The VDO gauge is used by many people here. Its accurate, reliable and is similar looking to other gauges.
Agree with you 100% on that. Getting rid of the stock unit is a good thing to do, especially if it's still got the signal conditioner in it. As I said, that and the oil lines are imperative to change out.
Old October 5th, 2015, 03:56 PM
bababoris
Boris Kogan
1993/Defender 110
Quick update. Had the vdo unit installed and it looks way better. Thank you all for your help and input
Old October 5th, 2015, 04:01 PM
Help spread VDO!
Old October 5th, 2015, 04:33 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I am also having gauge issues. My gauge stopped working all together. Tried cleaning the connector at the sender with no improvement. The sender is original so I'm hoping that the culprit but is there a way to check the sender with a voltmeter? Isn't it just grounding source? If I ran jumper wire from the connector on the wire to the intake manifold or something wouldn't the gauge read full hot and I'd know it's the sender?
Old October 5th, 2015, 04:52 PM
Great move. I have a stack of the original gauges if you bump your head and want to go back to having a stupid gauge that does not work right.
Old October 5th, 2015, 06:01 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by bababoris View Post
So I got my truck back. Guys at Huntington service in So Pasadena were great. They replaced the gage and sending unit but could not find a gage that looked close enough to the original. Attaching a pic of the new gage. They said something about the older gages not being able to work with sending units wherr they had to account for higher Temps that defender run. Or something like it. I kept the original gage. Any chance the original gage can be repaired? And should I call around defender parts stores to see if I can find an original working gage and sending unit?
Attachment 128792
Any 12V gauge will work as long as the sender is actually matched to the gauge and the unit is wired properly.
RDavisinVA
200TDi Temp Gauge & Sender issue Jonesy Smaller Projects 9 September 29th, 2014 01:11 PM
VDO Temp Gauge issue sloanfiske Defender Technical Discussions 24 August 6th, 2014 11:24 PM
Heater temp control issue... silverlight Defender Technical Discussions 15 January 3rd, 2013 12:03 AM
temp sender issue melittle Defender Technical Discussions 6 November 5th, 2012 01:20 PM
200 tdi Temp Sender Issue Wolf Fabrication Defender Technical Discussions 13 January 14th, 2010 12:35 PM
