Temp fix for leaky swivel ball seal? - Defender Source
Old June 28th, 2005, 09:37 AM
solihul
Rover
My swivel ball seal is toasted and has thrown all the one shot grease out - the steering now is ver hard. This morning I re-filled it with 80/90 gear oil and it's much easier to drive but it's getting thrown out all over the inside of the wheel and hub. Any thoughts on what might be the best short term solution to keep lube inside? Maybe a combination of one shot grease and gear oil?
Has anyone written up the procedure for replacing the swivel ball seals?
Thanks!
Old June 28th, 2005, 10:44 AM
Some helpful links.
http://www.expeditionlandrover.info/LRhubseal.htm
http://www.jpurnell.com/RR/repairs/s...all%20info.htm
http://www.roversnorth.com/RRD04/RRD...D04_page42.htm
Old June 28th, 2005, 03:20 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
you could always cut a new seal replace the old with the cut one then use silicone to seal the cut.
Jimmy Buffett
Old June 28th, 2005, 03:48 PM
solihul
Rover
Has anyone had success with the "cut seal" method?
So you just clean the area, pull off the old seal and cut it off. Then carefully cut the new one and tap it into place with the cut side at the very top then seal it with silicone?
That sounds like the best way to do it. Anyone know what the part number is?
Old June 28th, 2005, 03:49 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
If your steering has suddenly gotten very hard you may have more problems - I exploded a CV joint cage on the way to MAR last year in my Range Rover - some of the chunks of the cage got between the outer housing and the swivel ball and caused heavy drag on the steering. Smaller chunks got into the seal and caused it to leak. Sudden large leaks are very suspicious - these seals tend to start slow and work up to a big leak - unless a stick got jammed in it.
On other rovers when the seal started to leak I've had good luck taking a small hook tool and carefully cleaning out the trash that's behind the lip of the seal - sometimes some mud or stuff gets behind the lip and causes a leak - a good flossing will sometimes cure it.
Old July 2nd, 2005, 05:47 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Just do it right to start with....
Road wheel off, brake caliper off and tied out the way, undo the 7 bolts that hold the swivel onto the axle case, swivel out complete with drive shaf t& CV in situe, undo the small bolts that hold the seal in position, new seal in and assembly is the reverse of disassembly. Oh and the whole thing out in a oner is bl**dy heavy
Proper job
If your steering has gone heavy you may be too late for a quick fix. The CV joint may well have already eaten itself.
Best strip it right down before an accident is caused
Mike Hammond
swivel ball seal parts hotroddef90 Defender Technical Discussions 19 February 9th, 2014 03:26 PM
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Swivel Ball Leak... norros Defender Technical Discussions 19 May 5th, 2004 03:50 PM
