Temp. at Ypipe gasket? - Defender Source
Old September 7th, 2005, 08:19 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I found a sealant for a small leak from where my y pipe meets the manifold. I have tried tightening the gaskets ect. and no luck. The sealant has a heat resistance of 2300 continuous and intermit. 3000degrees. Do you think it will burn off. Just want to try one more thing before pulling the manifold.
http://www.rmoreau.com/mms3500.htm
here is the product....
Old September 7th, 2005, 08:56 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I don't think burn off is a problem--I think the challenge is if the pressures there will blow it off/out. I would probably apply it, let the car sit for a few hours then idle the car for a few minutes without any high rpm throttle to help the curing process along and then let the truck sit overnight to fully cure it before driving it.
Old September 7th, 2005, 09:04 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks I will give it a try.
Old September 7th, 2005, 10:35 AM
It says exhaust repair on that page, I bet it will work fine.
gas
Wont run at temp Neo Defender Technical Discussions 12 February 24th, 2006 06:54 PM
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
