Temp - Defender Source
Old August 18th, 2016, 01:24 PM
atpick's Avatar
atpick
Andy
1990 110
Temp
Driving home today and the temp is in the upper white range. Cause for concern? Thoughts? Haven't had a chance to use the IR gun yet.
Old August 18th, 2016, 01:26 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Time to get a VDO gauge with numbers, colours have no meaning. But in your pic that would be normal?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 18th, 2016, 02:14 PM
Not in the red is in the green in my book unless you are using the CRM model. If so then you may be in the yellow and should vocalize that to your crew mate. Always use good CRM!
Old August 18th, 2016, 02:17 PM
just IR gun the thing.
Old August 18th, 2016, 03:10 PM
atpick's Avatar
atpick
Andy
1990 110
Originally Posted by javelinadave View Post
Not in the red is in the green in my book unless you are using the CRM model then you may be in the yellow and should vocalize that to your crew mate. Always use good CRM!
Red over white, good for flight!
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Thermostat could be starting to stick reducing flow. Mine did the same thing. Back to normal with a new thermostat.
Black Rhino Lives Matter
Old August 18th, 2016, 03:31 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
The great news is your gauge appears to be living up to its end of the bargain. When is the last time you serviced your cooling system?
Old August 18th, 2016, 05:53 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
My 2.5NA would always be up there while on the highway, that was with a 1.6 and doing 60 the whole time though.
Temp Sender Location DJ Menasco Defender Technical Discussions 10 August 28th, 2006 01:24 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
