Tell me why this won't work alloys on salisbury rear - Defender Source
Old May 1st, 2009, 05:30 PM
I want to cut down the end of the axle and use a front drive member off of a D90/RRC/DI and the non-ABS hubs and the disc brake brackets and everything else.
Ron
Old May 1st, 2009, 08:36 PM
based on what I found when doing my front 24 spline conversion to my 84, I think that at least as far as the hubs go, you will be fine as long as the spindles, hubs, and drive flanges are from the same axle generation. my late 24 spline flanges would not work on the early 10 spline hubs and vice versa. on the old hubs the stub axle protrudes about 1/2" form the flange/hub mating surface and so the drive flange has a deeper recess to accomodate this. the later 24 spline hubs stick out further so combining the new hub and old drive flange will leave you unable to fit the snap ring among other problems.
hope that helps...
Ron
Old May 1st, 2009, 10:24 PM
Doh!
I didn't want alloys anyway
Old May 2nd, 2009, 08:42 AM
You can run alloys on the salsbury rear - as long as you don't expect to have center caps
Old May 2nd, 2009, 09:05 AM
That looks stupid though.
Old May 2nd, 2009, 06:40 PM
I'd be willing to bet a "bump out" center cap is available in the UK somewhere. We can't be the first people to want to do this.
Old May 2nd, 2009, 07:18 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Or just run wheel spacers..
Legend in My Own Mind.
Old May 3rd, 2009, 01:32 PM
Spacers big enough to not needs caps are very pricey. You could swap axles out for less.
Old May 3rd, 2009, 02:25 PM
true dat. been there done that, got the tshirt
alloy
Rear driveshaft geometry - changes? kiphartzell Defender Technical Discussions 1 March 11th, 2006 02:45 PM
110 rear diff protection (Salisbury diff guards) dave_lucas The Vendors Loft 13 October 25th, 2005 09:08 AM
Rear Work Lamp rover4x4 Misc. Chit-Chat 5 February 19th, 2005 12:41 PM
Rear recovery point souza Defender Technical Discussions 33 September 22nd, 2004 11:41 AM
» Defender Registry
Murphy
NealK
Grover
Cobramax
Add your Defender
