tdi vs v8 clutch plate - Defender Source
Old May 17th, 2014, 10:34 PM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
I've got a question for the experts....I'm working on a project and need a 9.5 inch land rover clutch plate that will work with an R380 removed from a 1996 v8 discovery (NAS). I understand the v8 clutch plate is 10.5 and won't work but I've received conflicting information regarding the 9.5 tdi clutch...is the spline count the same? My v8 clutch plate is for a 23 spline shaft...is the tdi spline count/diameter the same? Could someone with access to both a v8 and tdi compare the two for me?
Thanks in advance
Frank
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old May 18th, 2014, 01:04 PM
robertf
Robert F
1995 Discovery
According to rock auto the 300 tdi clutch plate is 23 spline. I could be wrong, but I think all you will need is a custom pilot bushing with the tdi od and v8 id and just use off the shelf 300 tdi stuff for the rest
Old May 18th, 2014, 02:28 PM
Mtanzania
Frank
I appreciate the response. The kit I have purchased comes with the proper pilot bearing...I was just hoping someone knew for sure if the shaft size and spline count were the same between the v8 & tdi
94 D1 300tdi - Sold
Old May 18th, 2014, 06:45 PM
The spline sizes are the same. The engagement depth of the splines and pilot bearing diameter and depth are different.
Old May 18th, 2014, 06:50 PM
robertf
Robert F
1995 Discovery
Does the spline depth difference affect functionality?
Old May 18th, 2014, 06:59 PM
Mtanzania
Frank
Thank you!
94 D1 300tdi - Sold
Old May 18th, 2014, 07:03 PM
I think the problem is using a V8 input shaft on a 300TDI (not enough spline engagement on the cliutch). It is probably okay in the other direction with the right custom pilot bearing but I don't know anyone that tried.
clutch, tdi, v8
Bulkhead VIN plate and 4WD plate and tow plate o2batsea Series Technical Discussions 3 July 16th, 2013 03:12 PM
Clutch/press plate question wantone Defender Technical Discussions 6 May 21st, 2012 10:31 AM
Td5 clutch and pressure plate ECR The Vendors Loft 3 March 9th, 2011 05:20 PM
Clutch Pressure Plate Question bstraw Series Technical Discussions 4 November 30th, 2010 02:44 PM
Determine clutch pressure plate wear cgalpin Defender Technical Discussions 5 November 19th, 2010 07:14 AM
