Tdi VDO oil pressure sender help - Defender Source
Old March 20th, 2009, 12:36 PM
I have a 200tdi and went to install the light bulb shaped VDO oil pressure sender and the sender cannot reach into the small space. What type of m10 adapter have others used to space the sender out ?
Old March 20th, 2009, 03:21 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Hi Doug, I installed a VDO mechanical oil pressure gauge and teed off from the original sender unit to keep the light pressure switch to one side and the pick up or in your case sender unit on the other. Picked up the tee at local part store.
Pat
Kirk Lazarus, Tropic Thunder
Old March 20th, 2009, 05:12 PM
The sender I have has a 7lb warning light sender as well as the gauge sender-thats part of what makes it so large. Guess I'll search some more for some sort of 10m male/female extension but had little love from google.
Old March 20th, 2009, 07:42 PM
Retrofit's Avatar
Retrofit
Pat
I know for a fact that there is not much difference between standard thread and metric in this size. So at least you can check that for maybe a 90 degree or something similar.
Sorry I couldn't be more helpful.
Pat
Old March 21st, 2009, 05:12 PM
Looks to be a VDO part # 230-033 thats required. Found this picture on Expedition portal.
http://www.expeditionportal.com/foru...d.php?p=349072
having some fun finding the adapter
Old March 22nd, 2009, 08:52 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Is the threading the same on the 300? If so, I agree with Pat, its VERY close to 1/8 NPT I believe.
Old March 23rd, 2009, 01:33 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Did you get the vdo sender from egauges? The one that looks like a tiny oilfilter with 2 conectors on top
Old May 6th, 2009, 09:40 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Doug, did you get resolution on this?
Old May 6th, 2009, 10:24 PM
nope. Have the tach and boost hooked up. Haven't been driving the Tdi, so out of sight out of mind. Dropped the ball on finishing over a $3 chunk of brass.
Old May 6th, 2009, 10:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
So do we know if the 300 and 200 are the same? It sounds like 360-006 may work on the 300tdi -- can anyone confirm?
Doug, you coming tomorrow?
Old May 6th, 2009, 10:33 PM
where ? did you guys ever work that out ?
Old May 6th, 2009, 10:34 PM
Abrooks's Avatar
Abrooks
Tony Brooks
It's at Jays.
Old July 31st, 2014, 10:29 PM
What was the verdict on the threads for the light and the adaptor?
Also which sending unit did you ultimately go with for your 200Tdi?
Old July 31st, 2014, 11:05 PM
This work for you?
https://www.unicorpinc.com/metric_10mm_maletofemale.htm
Mark Kellgren
KM4BOR
Old August 1st, 2014, 11:49 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I just finished my oil pressure gauge project last night using the VDO gauge and their 1/8npt sender w/ warning light.
Probably being overly conservative but with the diesel I wanted something better than the typical brass VDO/Autometer adapters and found this one:
http://www.mscdirect.com/product/details/84433465
Appears to be a well made piece, plated steel, larger than the brass ones with an o-ring and crush washer seal on the engine side. It is a bit longer too so clearance from the injector pipes is not an issue (on the 2.5na).
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old August 1st, 2014, 12:08 PM
Thanks Wayne, that's exactly what I am looking for!
tdi
Has any one installed a VDO oil pressure sender on the '97 - 4.0? LenB Defender Technical Discussions 8 March 29th, 2010 01:30 PM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
