TDI spill return - what's the ID? - Defender Source
Old April 21st, 2016, 12:16 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
i need to temporarily repair the spill return lines so I can drive the truck to SCARR tomorrow. Trevor doesn't have the 200TDI spill return in stock right now... Does anyone know the inner diameter of the lines?
Thanks!
Old April 21st, 2016, 12:33 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You got a Mercedes dealer in town, pt#2122.0.207/20 the open end looks like 3mm.
Got a nice new roll sitting on my lap, of which is no good to you I know.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 21st, 2016, 12:50 PM
I believe you can use this (experts please correct if wrong)
High Performance Silicone Vacuum Hose - 5 feet - 5/32" ID (.156"|4mm) - Black
http://www.amazon.com/High-Performan.../dp/B008N0VNXC
Old April 21st, 2016, 01:00 PM
I use clear silicone 1/8 ID
Old April 21st, 2016, 01:03 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Tygon chainsaw gas line works great too, the small stuff, any small engine shop will sell it (it's a yellow colour)
JL
Old April 21st, 2016, 01:30 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Thanks guys. I assume just a regular hose clamp is fine since it's not high pressure.
Old April 21st, 2016, 03:26 PM
No clamps needed just push on
Old April 21st, 2016, 03:47 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Thanks!
Go to a Mercedes parts place, dealer, or shop.
Line is the same as 60s - late 90s.
Not a good choice.
RDavisinVA
Old April 21st, 2016, 04:33 PM
Originally Posted by rdavisinva View Post
Not a good choice.
Too big at 4mm ID ??
Old April 21st, 2016, 05:31 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I used to use clear vinyl on my diesel rabbit, it did discolor & get stiff but it didn't leak. Had it on there for a long time.
Old April 21st, 2016, 06:00 PM
Yes, 4mm, 5/32 is the correct size. I use silicone vacuum hose at that size with spring clamps. It is nice and flexible and should last forever.
Old April 21st, 2016, 06:02 PM
I should add... This is with the later style spill rail. The original style used nylon tubing and would be different. My suggestion if you have the early style is to buy the new style and replace the buna-N hose that comes with it.
Old April 21st, 2016, 06:46 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
How do I know if it's the later style? Engine is a disco 200tdi.
Old April 21st, 2016, 08:13 PM
They old style has nylon tubing (it is stiff) like the rest of the fuel lines. The newer style has flexible hose. The is just the three hoses joining the injectors.
tdi
200tdi spill rail leak El Solis Defender Technical Discussions 27 June 24th, 2016 09:01 AM
300tdi Fuel Spill Return MJN100190 Z.G For Sale - Parts 1 December 4th, 2015 02:32 PM
Spill Return Lines - 200TDI javelinadave Defender Technical Discussions 17 April 10th, 2014 03:24 PM
Coolant Spill Davis Defender Technical Discussions 6 July 9th, 2013 03:26 PM
200tdi spill rail Banjo bolt torque tomaco1 Defender Technical Discussions 4 April 19th, 2012 03:29 PM
