Tdi Smokey on start up - Defender Source
Old April 18th, 2008, 03:56 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Here's the story - Rebuilding the 110 (pics to follow on the rebuild thread) engine laid up for about a year. It's a 200tdi, changed the oil - flushing oil first as I do every second or third change then the usual 10W40 semi synthetic. It's smokey as a very smokey thing
when cold, clears as the engine warms on a fast tick-over after about 10 minutes idling smoke is blue to blue/ white when revved. There are next to no fumes coming out of the oil filler cap when the engine is running hot or cold.
Any ideas?
Valve stem seals???
Injectors??
Thanks for any help
Mike Hammond
Old April 18th, 2008, 09:13 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Wink
Any ideas?
Valve stem seals???
Injectors?? I WOULD CHECK THESE NEXT
Thanks for any help
good luck with it!
legend in my own mind
Old April 18th, 2008, 11:14 AM
You probably have low compression on a cylinder or two or maybe retarded timing. If you get in and drive, do the smoke clear after the first acceleration?
Do NOT warm the engine on idle, even high idle. Start it and drive it. You need to get the EGTs up so that all cylinders are burning. The EGTs won't come up until the engine sees a little bit of load. If you let them run cold like that, unburnt fuel will get on the rings and carbon them up.
Old April 18th, 2008, 12:57 PM
mikeslandrover
Mike Hammond
Well after some conflicting advice - it's the valve stem seals for sure followed by the valve stem seals never give any trouble at a different shop and it's, the injectors or it's the timing and it's because it's sat for so long the only thing I was confident about was that it was the engine that was making the smoke and it wouldn't pass its emissions test like that!
I went for the cheapest option first and gave it a large shot of injector cleaner. It worked the fumes are so clean you could practically breathe them... but not for long. So It's sorted, thanks for your input,
Mike Hammond
start, tdi
300 tdi slow to start discotdi Defender Technical Discussions 22 October 27th, 2009 08:54 PM
Think a TDi Discovery fits the bill - so where to start? turbodave Defender Technical Discussions 6 August 5th, 2008 10:22 AM
