tdi smoke - Page 2 - Defender Source
Old December 4th, 2006, 01:45 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
It will be a simple thing, like a can, one hose in, one hose
out. I'm doing it with second hand but good quality material,
all stainless steel. Still have to drill holes, place a draining
tap, etc... In pipe will be longer than exit pipe, still have to work
out some details, any idea is welcome.
Adding 3 pics (attachments).
ID:	7565   Click image for larger version
- Charles Eames
Old December 4th, 2006, 03:52 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by D90user
So I have noticed a little more smoke lately. White on startup untill she warms up a bit. That dosn;t worry me but when driving at night the headlights behind me illuminate smoke under load on the freeway... looks light in color but I can't tell.
Also I have noticed a slight blue color to the smoke sometimes ( ) My compression is even, and I don't seem to be burning oil. Timing belt is new, and intercooler is clean.
What should I do? I havn't adjusted the valves in a while so I'll probably do that next.
How much smoke is "norma"l for a tdi?
When adjusting the injector pump do you guys have any hints on how to get it right?
thanks in advance
Good link: http://www.freeautoadvice.com/diesel/smoke.html
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 12:00 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Forgot to say that i'm planning to bolt it near
manifold, couldn't find a better place yet.
- Charles Eames
Old December 5th, 2006, 12:19 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Turn up the boost to help the engine burn the fuel. This is often forgot when trying to tune the engine correctly. Often 300 tdis are only pushing 13-14 boost. 16 is the factory setting. Be sure to start thier before turning down the pump. And cleaning the intercooler should be a regular maintenance.
JP
legend in my own mind
Old December 5th, 2006, 12:54 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Good call Pendy.
Old December 5th, 2006, 01:29 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
JP
Did you do this? Because last time I drove behind you I got so high on Diesel fumes I thought I was on the magical mystery tour.
BTW, It was awesome.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 5th, 2006, 01:37 PM
MonLand
Loic Fabro
How do you turn on more boost?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 01:44 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
And more boost means less fumes ?
- Charles Eames
Old December 5th, 2006, 02:32 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
More boost can mean less fumes ( the pump will put some extra fuel in because the boost is higher). Higher pressure means more heat = lower density of air going in. therefor you really need an intercooler with a bigger surface cooling area to increase the density of the charge going in. More O2 = a more complete burn and less smoke and more power
at this point most people turn up the fuel more and get more power and smoke (a bit) and if my experience is anything to go by a better fuel economy
Mike Hammond
Old December 5th, 2006, 04:36 PM
MonLand
Loic Fabro
So.... Is that a electronic switch somewhere? A mechanical switch? Just a matter of pushing the pump a little further? I would love to give that trick to my dad so that he stop complaining about his 300Tdi smoking from time to time.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 05:07 PM
D90user's Avatar
D90user
steve
Mike-
I believe Pendy was refering to getting the boost back to stock, meaning that many tdi through age or whatever are not running the factory setting of 16 lbs. If you want to trun it up more then yes a bigger intercooler is needed.
Old December 5th, 2006, 05:11 PM
MonLand
Loic Fabro
Mike-
I see so, it means that the fuel (well...diesel) pump has to put out those 16 lbs, then! :-) Now that makes sense, I was under the impression that there was something else I needed to learn about.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 10:44 PM
pendy's Avatar
pendy
jim pendleton
89'd90
16 lbs boost from the turbocharger that supplies air to the combustion chamber under pressure instead of vacuum. The mechanical wasgate linkeage can be adjusted to give more or less boost. The factory upper limit is 16 lbs. This is all seperate from the injection pump (diesel pump) which is another factor.
And Bucky my smoke screen is very delibrate, as you know.
JP
Old December 5th, 2006, 11:56 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
One idea,
If you are really desperate to get rid of all smoke and not willing to suffer a loss of power, inject propane. More power, slightly better gas mileage, no unburned fuel.
Personally, I am trying to find ways to increase my diesel smoke. In honor of Pendy.
edit: You really don't know what smoke is until you drive a 2.5 N.A. military Rover Diesel. I could make a smoke screen that would make James Bond jealous.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 6th, 2006, 01:50 AM
D90user's Avatar
D90user
steve
you should see my 1980 VW dasher diesel... smoking like hippy... makes me feel like I'm going faster
Old December 6th, 2006, 09:02 PM
MonLand
Loic Fabro
I second that! But it does not need to be the military version.....
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 6th, 2006, 10:25 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Really? This whole time I just assumed it was some kind of military camoflage, or counter-detection device. I mean, why else would mankind invent and produce a motor that produced 67 H.P. and 17 vertical feet of black smoke!?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 6th, 2006, 10:31 PM
MonLand
Loic Fabro
Because then, with a short 1st gear, you can take on the sports car at the traffic light. As long as you start on the right-hand side lane and get ahead of them for the first 10 m, you can smoke them so bad that they'll give up. C'm'on is that simple!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 7th, 2006, 03:33 PM
mikeslandrover
Mike Hammond
You shorten the rod to the waste gate+ more boost, there is a thread with the pump tuning instructions in it from a couple of years ago...
Mike Hammond
Old December 7th, 2006, 05:16 PM
MonLand
Loic Fabro
Took a bit of searching, but.... here is the thread:
http://www.defendersource.com/forum/...5&postcount=35
MonLand
1995 D90 NAS
1996 Discovery NAS
tdi
tdi blue smoke D90user Defender Technical Discussions 11 November 15th, 2007 11:07 AM
ECR New SS Exhaust Kits Coming soon TDI Too TDI Guy Misc. Chit-Chat 19 October 22nd, 2004 05:16 AM
