TDI sediment filter - OEM is Delphi CAV filter? - Defender Source
Old October 25th, 2010, 11:14 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I was thinking of fitting a sediment filter to my 300TDI and after looking the OEM filter & exploring some aftermarket options it looks like the OEM might be a Delphi 5836B120:
http://www.roverparts.com.au/fuel_sedimentor___diesel1
http://www.dieselpartsdirect.co.uk/P...phi-Sedimenter
They look about the same to me - of course the Delphi unit is much cheaper than LR-tagged. For you TDI guys - does this look like the same filter to you?
Old October 25th, 2010, 11:24 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
They both do the same thing, in fact I like the glass bowl on the Delphi unit but you would not want to mount that in the wheel well. Under the hood would be fine I guess.
Old October 25th, 2010, 03:33 PM
Personally....if I were to add something, I would put in a "pre-filter". A Standayne PM-100 with a 30 micron head or a Racor or such.
oem, tdi
300 TDI air filter housing/hoses sundogcwolfe Wanted 1 December 24th, 2009 09:32 AM
300 tdi air filter to turbo hose discotdi Wanted 4 August 16th, 2009 07:18 PM
200 Tdi oil filter equivalence ... Retrofit Defender Technical Discussions 11 January 27th, 2009 05:39 PM
TDI Heated fuel filter Overlander Defender Technical Discussions 16 July 15th, 2008 01:03 AM
