Tdi proper startup after oil cooler lines replaced - Defender Source
Old August 4th, 2006, 03:12 PM
artm
Arthur Maravelis
97 SW
Just finished replacing the lines on a Tdi. Any special procedure before I start her up? I guess I'll fill the oil cooler (with the bottom line connected) and top line manually.
Old August 4th, 2006, 03:21 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Dosn't the oil cooler drain every time you change the filter anyway? I'd just fill the girl up, start it, shut her down and check again. I'm sure this is not correct due to the oil pump not being properly primed but does it really matter...really?
Thats what I did with mine...
Old August 4th, 2006, 03:24 PM
Start her up and go.
Old August 4th, 2006, 03:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
just fill the oil as you usually would...
Legend in My Own Mind.
Old August 5th, 2006, 06:06 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I try and get some oil in the filter when I change that but otherwise just start it up and the oil pressure is there after a couple of agonising seconds!
Mike Hammond
Old August 7th, 2006, 11:59 PM
pendy's Avatar
pendy
jim pendleton
89'd90
You can disconnect the power to the fuel shut off solenoid and crank the engine over a few different times at 20-30 second bursts with rests for the starter between cranks. The oil light will probably go out while doing this.
JP
legend in my own mind
ac, start, tdi
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil cooler lines revisited rover4x4 Defender Technical Discussions 5 July 9th, 2004 08:40 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
