Tdi pre-filter draining tap - Defender Source
Old March 9th, 2010, 09:27 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
On Tdi's there is a pre-filter close to the tank
designed to trap the water in the system.
That pre-filter has a draining tap/plug.
My plug is in so bad shape that i can not
figure exact diameter and thread.
Anyone know the size and specs of this
plug ? any substitute for that really weak
plastic part ?
- Charles Eames
Old July 20th, 2010, 12:26 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
bump.
- Charles Eames
Old July 20th, 2010, 02:51 PM
i think that is called the sedimenter. is this the right plug?
http://www.britishparts.co.uk/.sc/ms...20DRAIN%20PLUG
Old July 20th, 2010, 05:06 PM
Chaucer
Will
93 110 | 97 90
Not exactly sure - but I think it is a standard 6mm x 1.0 threaded bolt.
Old July 20th, 2010, 09:02 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Looks like this is the one. I was thinking about having one made in brass because the plastic one is real crappy. I guess i'll order a new one just to check the thread.
I have low metal workshop labor cost down here, maybe a group buy ?
- Charles Eames
Old July 20th, 2010, 11:46 PM
Chaucer
Will
93 110 | 97 90
I'd be down for at least two. The same plug will fit the filter that is under the hood.
Old July 21st, 2010, 04:53 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Yup, that's the sedimentor. handy if you fill up from jerrycans or a crappy fuel pump, they collect a lot of rubbish out of the fuel (shame I can't fit one to the Td5)
part number for that crappy plastic bung is 37H7920 4.66 UKP
Old July 21st, 2010, 01:34 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm ordering one then i'll quote for brass ones (or aluminium ?) then i'll bring back the thread.
- Charles Eames
drain, tdi
300 TDI air filter housing/hoses sundogcwolfe Wanted 1 December 24th, 2009 09:32 AM
300 tdi air filter to turbo hose discotdi Wanted 4 August 16th, 2009 07:18 PM
200 Tdi oil filter equivalence ... Retrofit Defender Technical Discussions 11 January 27th, 2009 05:39 PM
TDI Heated fuel filter Overlander Defender Technical Discussions 16 July 15th, 2008 01:03 AM
