TDI oil 'catch can' - Defender Source
Old July 8th, 2010, 11:47 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
TDI oil 'catch can'
OK a quick question for the TDI guys that I have not had the time to research myself--- the little black oil catch can (AKA oil seperator/crankcase breather) could it eventually "fill" up? If so, what would happen? Shots of straight oil into the turbo intake? Should this be something to check on every one of these 25yr old import trucks when they come in the door?
Old July 8th, 2010, 01:35 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
It has a filter in it that needs to be cleaned. You also have the option of fitting one like the Alloy one Allisport does which does not need to be cleaned.
Old July 8th, 2010, 04:41 PM
It should have a hose that drains to the sump.
Old July 8th, 2010, 07:04 PM
ajh
Andrew J. Hutton
They do, and one to the air-cleaner housing, but they also have a metal gauze filter in them which will clog over time and needs cleaning.
Old July 8th, 2010, 09:57 PM
It should not clog unless you are using crappy oil or there is something wrong with the engine.
Old July 9th, 2010, 09:25 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I know it's not very "green" but i unplugged the hose for the oil vapor that goes to the air duct and route it to the ground. I have the alloy breather, works very well. There is a long thread about this specific topic, search "mann pro-vent".
- Charles Eames
tdi
using home heating oil in Tdi artm Defender Technical Discussions 17 October 19th, 2005 03:00 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
