Tdi Muffler - Yes or No? - Defender Source
Old July 11th, 2010, 11:44 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
My 200tdi has a cheapo offset muffler on it and I am considering removing it and running straight exhaust. Has anyone with a tdi done this? Any noticeable reduction in heat or increase in noise?
Semper Fi!
Old July 11th, 2010, 12:19 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I have both - a lightweight with a 200 and a D90 with a 300. Lightweight has a muffler and the D90 is a straight pipe. I don't hear much if any difference.
Old July 11th, 2010, 12:22 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, mine seems pretty pointless and is actually doing more harm than good.
Semper Fi!
Old July 11th, 2010, 01:39 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Any performance gain by going the 3" route from front to rear with nothing but straight pipe ?
Thanks !
Pat
Kirk Lazarus, Tropic Thunder
Old July 11th, 2010, 01:40 PM
discotdi
Todd Miller
Land Rover
I thought the turbo needed a little back pressure from the exhaust to work properly. At least that is what I was told. not true?
Old July 11th, 2010, 02:44 PM
Wolf Fabrication
Sterling Archer
'08 D3
I pulled the muffler and there is no difference in sound at idle, but it's of course a little louder at speed. I did not notice any difference in performance and really wasn't expecting any. My "stock" muffler and the pipe behind it were in the way of a lot of things, including my auxiliary air tank and A-arm.
Semper Fi!
Old July 11th, 2010, 03:30 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks !
Pat
I have been running straight 3in pipe from the header back with one bend in it for a long time. It is louder. Not obnoxious, but louder. There is a noticable difference in EGT's. They still climb but they fall MUCH quicker. If you have the motor tuned up, its a great mod.
No truth to this. On a diesel, the less backpressure the better.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 11th, 2010, 03:56 PM
GreenRover's Avatar
GreenRover
Frank S
1984 D90
Just had mine taken off of my 300tdi D90. There really is no noticeable difference in sound and it looks a lot cleaner with a simple chrome tip down pipe.
Old July 11th, 2010, 06:05 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
No muflers.. Just a SS straight through resonator...
Legend in My Own Mind.
Old July 11th, 2010, 06:33 PM
turbos need a little backpressure.
Old July 11th, 2010, 08:13 PM
Straight pipes are not much louder in the vehicle, but for people outside, in the direction of the exhaust, it is quite a bit louder.
Old July 11th, 2010, 08:56 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It is louder. I wheel with no top on and it is noticable. Not terribly annoying, but louder.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 11th, 2010, 09:02 PM
jac04's Avatar
jac04
Jeff
Currently Roverless
Backpressure downstream of the turbo will only limit the turbo's ability to do the most work possible with the available inlet pressure. Ideally, you want NO backpressure after the turbo.
Old July 11th, 2010, 09:13 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
I've never had a muffler on mine...
Old July 11th, 2010, 09:38 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Answer this honestly though. Was my engine little too loud when I was doing the suicide line on Claw?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 11th, 2010, 09:50 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm not understanding the difference between this and the factory set up. Do you guys mean taking out the silencer ?
- Charles Eames
Old July 11th, 2010, 10:42 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
based on how the develop the power to force the intake air, i'd agree.
you'd want as little resistance as possible before the turbo, but a little bit of resistance afterwards. correct me if i'm wrong?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old July 11th, 2010, 11:01 PM
You want no back pressure in the exhaust downline from the turbo. This allows the exhaust gasses which are being pushed out of the engine to pass through the exhaust vanes of the turbo as fast as possible. Maximum speed gives fast spool to boost levels. The turbo vanes themselves do a lot to quiet the exhaust note. When time allows I'm going to have a 3 inch made from the end of the downpipe back. On a 130 that noise should be far enough behind the passenger cabin the difference if any shouldn't be notice able.
Old July 12th, 2010, 01:18 AM
bharris's Avatar
bharris
Brad Harris
Not sure how to answer that...
it was loud, screaming loud even... but I didn't feel the need to have ear plugs (and I wear earplugs on the freeway with mine) so too loud? meh...
It's only loud when you've got your foot all the way in it
Old January 10th, 2011, 12:49 AM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
Any updates from folks living with straight through exhausts. I use my 110 for longer distance trips with the wife and kid. This past weekend the tailpipe separated from the rear silencer. I am thinking about removing the centre and rear silencers and having some stainless run straight back. I am hoping to avoid highway drone and excessive noise on the trail....
Henry
tdi
Flowmaster Muffler w/about 12K miles 1of40 For Sale - Parts 0 October 3rd, 2005 03:55 PM
Stock Muffler ? FlowMaster ? Others ? norros Defender Technical Discussions 24 June 2nd, 2004 10:56 PM
exhaust / muffler ? januconn92 Defender Technical Discussions 9 January 26th, 2004 07:03 PM
