Tdi Muffler - Yes or No? - Page 2 - Defender Source
Old January 10th, 2011, 01:46 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by Shearpin View Post
Any updates from folks living with straight through exhausts. I use my 110 for longer distance trips with the wife and kid. This past weekend the tailpipe separated from the rear silencer. I am thinking about removing the centre and rear silencers and having some stainless run straight back. I am hoping to avoid highway drone and excessive noise on the trail....
Henry
Turn your speakers all the way up. If you can live with that on the freeway for long trips, your fine.
It may depend on what your wife is like.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 10th, 2011, 08:23 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I still have no noise issues with mine, even on the highway.
Semper Fi!
Old January 10th, 2011, 11:08 AM
I use a walker dynomax SS muffler. You can see straight through it though it takes a slight jog to one side. Basically the equivalent of a 5 or 10 degree bend in the pipe. It is effectively the same as a straight through job. No idea how it compares to a straight pipe system in noise level. Above 55mph I can't really hear it anymore, except when I'm riding next to a jersey barrier or in a tunnel.
Old January 17th, 2011, 06:45 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
No muffler, sounds fine to me:
Old January 18th, 2011, 02:07 AM
d90dang's Avatar
d90dang
Matthew
1997 D-90
just curious but are any of you guys running cats in your diesel defenders?
Old January 18th, 2011, 04:37 AM
reb78
REB
Land Rover 110
I removed the centre box on my defender 110 200tdi (cut it out and welded a bit of pipe in its place). It had the marginally smaller 2inch (19J) turbo diesel exhaust on it. Silencer removal was just a cheap way of seeing if there were performance gains to be had before actually spending any money. Acceleration was much better, top end was improved as well, however, contrary to most reports i had read, it was noisier especially on the motorways. So i bit the bullet and had a larger bore (2.5inch) stainless system fitted with two silencers. Performance is as it was without the centre pipe but it is much quieter!
Old January 18th, 2011, 01:31 PM
exmod110's Avatar
exmod110
Don Lang
300tdi with the cat still on, 2.5" straight pipe, noise is not an issue with mine..
I am going to remove the cat in hopes of lowering the egt's with out having to reduce the fuel settings..
normal driving at 70mph with 285's and the 1.4 see's me at 800-1000 f ( piro is located where the egr valve was)
put more load like a head wind and it will quickly climb to 1150+ but has no prob holding speed, just gets the egt's warmer then i would like to see.
What kind of egt reduction would one hope to get by removing the cat?
85 exmod 110 rhd 300tdi
Old January 18th, 2011, 01:54 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Don't you love the sound next to a barrier?
Old January 18th, 2011, 02:03 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Straight through for me in the 110, on teh 90 too No issues. It really screwed up my fuel economy though!
Keith
Big, Red and ... aaa Red..
Old January 18th, 2011, 02:11 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Fun pedal get stuck to the floor?
Old January 18th, 2011, 03:10 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
It sure sounds cool when you mash that there skinny pedal!
Keith
Old January 18th, 2011, 05:48 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Loud pipes save lives. Oh, wait. Wrong forum.
Old January 19th, 2011, 12:04 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Ran with the cat only and stock turbo until a couple of years ago.
Then I got rid of the cat too.
Nice sound, but my ears were sore after the 3 1/2 hrs trip to the countryside (usually forth and back during weekends).
As to performance, it felt a bit sluggish.
Then I got an Equipe mid-silencer, which reduced the noise a bit and engine felt better.
Then came the VNT and I don't know anymore.
I'd like to make it straight-through again just for the love of that sound...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old April 15th, 2015, 06:43 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Heading to the muffler shop in town this Friday and I keep debating on what to do. I have a decat pipe and I was thinking of finishing it with 2.5" pipe and have no muffler or silencer. But, to get most anywhere out here you are hours in the seat and usually I just roll with the surrey top. I'm tempted to see what it's like without anything and then add something later if needed. But I keep going back and forth.
Old April 15th, 2015, 06:58 PM
Wolf Fabrication
Sterling Archer
'08 D3
I never looked back after removing the muffler. It sounded better and I am sure the motor "breathed" a little better too.
Semper Fi!
Old April 15th, 2015, 07:25 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
On my LWB, I ran 3" after the junction.
Too loud.
I don't know if it is the diameter or the length or the two combined but the harmonic distortion was... none too subtle.
Uncle Douglas followed me down the interstate and he could hear the drone a 1/2 mile back and can testify to the brutality.
YMMV.
Rent my
Old April 15th, 2015, 07:57 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
It definitely helps the engine breath and drops egts. I have just a straight through resonator only. No muffler Don't go larger that 2.5"
Legend in My Own Mind.
Old April 15th, 2015, 09:17 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
exactly what I used to have, dB was negligibly different
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old April 15th, 2015, 09:35 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I have a 2.5" straight pipe (no cat) behind my Tdi and I love the sound. Don't listen to Briggs, as that's just his feminine side talking.
Old April 15th, 2015, 09:41 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
edit......
------ Follow up post added April 15th, 2015 09:42 PM ------
edit...edit
------ Follow up post added April 15th, 2015 09:43 PM ------
edit...edit
tdi
Flowmaster Muffler w/about 12K miles 1of40 For Sale - Parts 0 October 3rd, 2005 03:55 PM
Stock Muffler ? FlowMaster ? Others ? norros Defender Technical Discussions 24 June 2nd, 2004 10:56 PM
exhaust / muffler ? januconn92 Defender Technical Discussions 9 January 26th, 2004 07:03 PM
